I think I installed the wrong cam
Brooks James
VET, CPT, Huey Medevac Pilot
Fruitland Park Fl
I was going over the paperwork on my car it shows the cam I have installed in my 92 magnum is a flat tappet hydraulic for LA ??? Besides HP loss what else ???
Yep! You thought right! Do you have roller lifers for the engine? If so I'd pull it back out and put a roller cam back in.
Yes, agree
Not upset. I'm actually have wanted a Hughes Whiplash cam since the first time I heard one.
Are you sure about that? I thought you had to start with a roller cam? The base circle is too small on a la. I maybe wrong tho
Positive. I've talked to Ken in depth about it. I'm still on the fence about it. I may get him to grind a small solid street roller on a stock slant 6 core. I haven't made my mind up. But he can do it.
7
May do that, custom grind would work
There is light at the end of the tunnel
I forgot I had a complete 360 mag stashed in my shed, that has a performance cam and valve springs, it spun a rod
Don't know the specs
When I looked at the cam lobes I could see, they looked pretty good.
There you go problem solved!
