racerjoe
Get in, shut up, hang on.If I have to explain.. People will never understand.
Kinda like when you took me on my first auto x rideGet in, shut up, hang on.
I called ride tech today and asked if these spindles are available outside of the complete kit and the rep I talked to (George Lewis) said they are and he’d actually just sent a quote to another customer a few days ago, so he just forwarded my the same quote to give an idea on what we’d be looking at for cost. Here it is.@HemiDenny , @DionR , @75slant6 , check this out! This is another Ride Tech product that come with their Mustang kits. It uses a S550 Mustang hub, so the bolt pattern is 5x4.5. They also have a caliper brackets that will allow the use of the S550 brake components. I'm not seeing these parts listed individually on their webpage, only included in kits. I kinda wish I would have found this earlier. This open options to use a factory Brembo caliper and have parts store availability for replacement parts.
Just start looking at stuff like this and those prices will seem much more reasonable. Radial X Spindles, Gen 3, 2005-2014 S197 SLA and 2015+ S550 SLA, Track, setI called ride tech today and asked if these spindles are available outside of the complete kit and the rep I talked to (George Lewis) said they are and he’d actually just sent a quote to another customer a few days ago, so he just forwarded my the same quote to give an idea on what we’d be looking at for cost. Here it is.
YIKES!!Just start looking at stuff like this and those prices will seem much more reasonable. Radial X Spindles, Gen 3, 2005-2014 S197 SLA and 2015+ S550 SLA, Track, set
Don't say that. I was just getting comfortable with the idea of a magnum swap. I don't need a reminder that a 6.4 can hit 500hp with headers and a cam...It's so good I sold the small block at Moparty. Don't need that where I'm going... Why did it take me so long to get on the bandwagon? I wish people would preach how good it is like I'm am. I need other people to make the same expensive decisions I do.
I'm sure we can figure out the right size. The extra grip from the wider tires will only make it more obvious that you are running on the soft side.Put down another 180ish street miles at Cruising the Coast yesterday with about 15 autocross runs in between.
Now that I have a fair amount of street miles and autocross miles on the G3 swap, I have a short list of items to upgrade/fix.
- I think I'm finally going to break down and buy the PSC power steering reservoir. The course at CtC had some high speed sections which proved my fluid aeration problem still exists. I was about 2.5 seconds behind the guys giving rides in pro level race trucks but I was only able to run about 60% of the course at 10/10ths due to the fluid aerating.
- I have the parts to get rid of the corvette filter/regulator. I will still need some fittings once I figure out what I need.
- Also coming up is a new set of wheels. I decided the cost to widen the fronts combined with the downtime wasn't worth it. I'll keep my current wheels and set them up with some normal street tires and put the 200TW tires on the new wheels. I'll finally have a 9" front and will step up to a 10.5" in the back.
- Finally, I really think I need a bigger front sway bar. After chatting with @bjkadron , I learned he's way smarter at the mathing required to figure out the right size bar. Once I get new wheels/tires, I'm going to corner scale the car and provide him with a bunch of numbers and let the magic happen.
Once the thought enters your brain... Welcome too the club!!Don't say that. I was just getting comfortable with the idea of a magnum swap. I don't need a reminder that a 6.4 can hit 500hp with headers and a cam...![]()
Yeah, this was the cam dyno chart I was referencing which is way more than you could put down well in most handling based A-bodies:Once the thought enters your brain... Welcome too the club!!
When you consider that the 6.4 is already rated (probably under rated) at 485hp in a stock "car", it's easy to believe that just adding a good intake, headers and a canned tune.. you're there at 500hp mark. I mean, we're only talking about grabbing 15hp. Alot of really good cam options with MMX, HHP, FRP that should easily put a stock rotator 6.4 at 550 with a good tune. But really, a 5.7 is just as sweet.. Amazing bang for the buck! If you haven't went for a ride in Tim's car since the upgrade, you should. Unbelievably smooth and the power is anywhere you want it. My Dart with a 6.4 is a slob but will make you smile and laugh with a vulgar display of power and torque, as the bench seat has it's way with you.. but Tim's, it really let's you see the full potential.
Btw Tim... I'm watching your trash cans. Get some upgrades, buddy.
I agree.. the supporting stuff is the big sting and what turns alot of people off. This A body swap really hurt, compared to my A100 hemi swap.. The A100 didn't need special headers, pan, steering box. I really didn't have anything invested in the 5.7 other than having the heads done with springs, a used 6.4 cam/lifters but the stand alones for the engine and trans. But, once it's done, it's done! I'll never go back on either one and no regrets.Yeah, this was the cam dyno chart I was referencing which is way more than you could put down well in most handling based A-bodies:
But you are right, the 5.7 with mild mods is a monster as well. it's the Hemi head flow that helps. Especially the Eagle ones.
Really my main concern is by the time you add all the supporting mods/swap parts for a Hemi you are in and extra 3-5k over your engine.
Yeah, Most people think shiny=fast which it definitely doesn't but when all they read is marketing how would they know better? Part of why I want to optimize with the stock stuff first.Went to cruising the coast again on Saturday. I usually just hang out and watch cars drive by all day on the Saturday of this event. A gentleman approaches me and asked what front suspension setup I had on the car, which I gladly provided the HDK information. He promptly says, "those coil overs must really make it handle well" To which I said it does handle well, but a shock and a spring isn't what make a good handling car, its the geometry of the suspension. He blows off my comment and asks about the rear, which I tell him its a leaf spring. He continues with, wouldn't it be so much better if you did a coil over in the back. Ugh! When will people stop thinking a damn shock and spring is what makes suspension superior to anything else?
Nah man. I'm an open book and have nothing to hide. I'm going with the Kansei Corsa. 18x9 and 18x10.5. I'm going to get some new 200TW tires for these and get some normal street tires for my current wheels. I figure if I'm already swapping in a race seat to go autocross, which takes all of 2 minutes, swapping tires won't be a big deal. 200TW tires aren't exactly cheap either.What wheels? Or are you keeping that under wraps until you have them on the car?
Most of what I have left is small block stuff. You don't want that junk...New wheels! Tell me more...
Again, stalking your trash pile
It's funny you say that.. When I'm scrolling fb and see sb posts on the Dart pages, I throw up a little bit in my mouth.Most of what I have left is small block stuff. You don't want that junk...
Pro tip: I was able to get 15% off their listed prices. They have feature on their webpage to get 10% off if you provide your phone number for marketing ads, which I've yet to get. Anyway, I added the wheels to my cart and didn't check out (got side tracked). About a day later they send me a text offering 15% off if I check out within 24 hours. So all 4 wheels for just over $1K. They are flow formed, not cast. They have been extremely responsive. I requested a drawing to check brake clearance and I had the drawing within an hour of sending the request. The wheels also shipped the same day I ordered them.
LOLIt's funny you say that.. When I'm scrolling fb and see sb posts on the Dart pages, I throw up a little bit in my mouth.
My current wheels have “tuner” lug nuts. I remember not knowing what the hell that meant, but apparently it isn’t anything special.I like them. Website says "* Tuner Style (60 degree conical bolts) are required.*"?
Very cool that they would send you a drawing, never thought to ask a company for that.
What size tires are you planning?
Did you post details of how your seat swap setup works? I remember you talking about it but maybe I missed the end result? What seat? Pic's please.![]()
