in Need of an oil filter adapter for a magnum engine
There was someone needing a plate a while back and they are discontinued from mother mopar.
Magnum year ranges were 1993-2003. You list “possible years 1967-1992” after your part number. Those are LA years. The oil filter plate is different for magnum vs LA.
i didn't know that till now. thanks for the info. with that said, what is the difference?
I have an external filter relocator and I took it off an 86 360 and put it on my 00 magnum and the difference was that the plate had several more holes for the oil flow than the la had but that is the only difference cause i bolted the la adaptor on my magnum using the magnum platewith the la stud pipe and they both use the same filter
There's more difference between the 2 plates than the amount of holes.
Thank You for your response. I thought that I had removed this post but I am no longer in need of a plate.
Thanks Again
You could have closed this if it was a wanted ad. In the future, start a parts wanted ad in the Marketplace forums. These ads in the wrong forums are deleted if we see them.
