Any body useing a stroked gen 3 hemi engine in there race car?
An acquaintance who is very familiar with small blocks (mid tens 68 dart street car), built a much more track oriented 6.1 for his race 68 dart.
Good for high 5s eighth.
Before I got kicked off face book. There was a red 87 dakota with a pretty much stock early 5.7 hemi with twin turbos. The second time around I think he made over 900 HP before it broke a rod..
Sounds like a guy I know and is local to me:
Are these engines supercharged? Might as well. Dependable 1000 horsepower.
That one isn't. 6.1, good heads, and the tall mf-er intake with a dominator on it.
Out local hellcat (of whatever varient) guys run 5s too, at about 1500 more pounds than that dart. Fastest of our three regulars run 5.30s, slowest runs 5.70s.
The Dart runs n/a 10.5, but isnt competitive. (It is a VERY competitive bracket combo, however!). A good friend of his is 2023 champ with a big inch W8 combo.
Didn’t know you knew him. I talked to him a while back, and we had a 45 minute conversation just on his intake manifold and what it took to make it work. Very sharp dude.
I switched over to gen3 hemi this spring.
I have 2 440s sitting in my garage that I abandoned.
Really happy with the performance but I need to get it more consistent
Not sure I am understanding you, but you said you had to run 7/8 spacers on top of the mounts to get the headers to clear?
I'll look and see if I got some pics of the underneath at the collectors to upload for you. Unfortunately, he's moved just far enough away to where I don't get to see him that often anymore. But when we did that, we shimmed the cab and bed up off the frame nearly an inch with aluminum discs we drilled through to make header clearance. Sort of a short body lift in order to get everything to play together.
What's all been done to your engine?
6.4 based
13.5:1 compression
.627 .255@ .050 cam
Drag pack intake with Dominator carb.
Heads are stock with manton rocker shafts.
Stock hydraulic roller lifters and rocker arms.
727 trans
What I'm amazed with is I shift this thing at 7,500 rpm and trap at 7600
6.4 based
13.5:1 compression
.627 .255@ .050 cam
727 trans
What I'm amazed with is I shift this thing at 7,500 rpm and trap at 760l
6.4 based
13.5:1 compression
.627 .255@ .050 cam
727 trans
I hope I can get my dakota close to that fast. Mine is only 11.1 compression. I bought a tall Ritter intake, but I will be useing a ATM 950 cfm carb. Here is a pick of what all has been put in my stroked 6.1
Well looks like I am for sure going to be building a gen3 hemi engine for my 91 dakota sport race truck now. Lol I found a guy that has a machined early 5.7 hemi block and a 397 k1 stroker kit with wisco forged pistions that comes with it. He was asking $3000 and I offered him $2500 thinking he would say no. Lol well to my surprise he said yes. Lol the only bummer is it will only be 11.1 compression with my eagle heads. I have a brand new set of stroker icon 13.5-14.1 pistons but they are for i think a 4.050 stroke crank and I think the kit I am buying has a 4.080 stroke crank. Oh well at least I can run the 397 on 93 pump gas now.lol the intake will be a Ritter with a 800 DP carb for now. Not sure on size of cam yet. But sorry for the long post. Was just interested in hearing other engine combos and how they run at the track. Thanks mopar65
I have a basic gen3 build in my Colt 2513ilbs with me.03 5.7 block, eagle heads, 13:1 , Prefix med rise intake, comp cam.Nothing special would like to build something bigger but want a stick.
