Post your 13 sec combos
Oh...... personal best
Considering my woeful technique and leisurely manual shifts i'm quite pleased
265 CI inch 6 cylinder
3 x weber DCOE45
pacemaker extractors to side pipe at rear wheel.
1.72:1 yella terra rockers
Jeep magnum sealed power pistons sticking up 40 thou above deck, edge profile to avoid head
Mirabito performance oil pump brace windage tray and baffle
steel vented flywheel
GM holden v8 10 inch clutch
Hercules street tyres 235 70 R14 no burnout
KYB gas adjust
standard springs
3.45.1 ratio rear with chinese eaton true track copy 7 3/8 inch R/P
Moser axles
slapper bars
cleaned up iron head with 1.6 and 2.01 inch valves
GM HEI module and GM '74-'76 6 cylinder truck coil
Vacuum advance connected up to 1 carb barrel with an alfa romeo alfa sud pulse smoother
drove 100 miles there and 100 miles back on 1.5 tanks of fuel
Dave
74 Duster
Stock bottom end 360 Magnum with aluminum Speedmaster heads
Comp XR274HR-10 Cam
Edelbrock Torker 2 intake
Quick fuel 750 Double pumper
A500 overdrive auto, stock converter
4.30 geared 8-3/4 rear
275-60-15 Nitto Drag radial
Never weighed the car but it's a full option street car with AC and cruise.
13.36@104.24
I'm confident I can tune it into the 12s. And yes, a better converter will help. This was the first time out with the new motor. Previous best was a 15.35 so needless to say I was excited!
Well, Season is over and I never broke into the 12s. I learned alot, finally learned my Nitto Drag Radials will actually get traction at 24PSI with a hellacious burn out. The only real good thing to come out of my last track day was an 0023 light that won me 50 bucks for best RT of the day!
Cley
I guess I should post the 318 Duster in here. 13.9’s in the 1/4 and 8.8’s in the 1/8.
Eddy on a cast intake, summit cam, headers, 2800 stahl, 3.55 open
1969 Dart. 4spd 2.47 1st with 3:91.1 spool 26” Hoosier slicks with SS springs. 360 10.8:1 308 heads with 1.94 intake valves. Single plane TM 5 750 Holley vac secondary. 1.9 60’ 13.89 @ 98.5mph. 6200’ altitude correction. Schneider 284/510 solid 110lsa 242/242@.050 with 273 rocker arms.
Blew up a lifter in my 413 and sent metal through it. now stock 383 with ported 906 heads, 474 purple cam ,torker intake and cheap roller rockers. So far 2 runs went from a 13.34@102 bumped up timing then went 13.11@103.
413 ran 12.38 in cool weather with stealth heads ,383 ran this in 85° 2,000DA.
want to thank everybody for the thumbs up ill keep you posted on our quest for 12's
a little update on our 69 DART took to norwalk for some tnt and with drag radials went from a 2.20 60 to a 1.8 and was falling on its nose at 5500 car would never rev past 5500 come to find out later that when i set rev limiter I set it at 5600 and not at 6500 car is set to shift at 5900 so next year I think we have 12's in the bag. Merry Christmas everyone and a safe and Happy New Year
1970 Duster 340, 2012 5.7 hemi from a truck. Stock except summit cam mds delete, locked vvt actuator. TTI headers, holly sniper intake with a Fast 92mm throttle body. 4spd manual and 3.91 suregrip. Ran 13.13 at 107.9 mph with a 2.00 60ft. Still working on the tune and the launch still more than a full second slower than than the stroked 340 I took out. Hopefully to get down to the mid 12s this season.
I have been racing there ever since I had my driver's license (1981) tech guy Duke Snyder recently passed away , he was there since the opening day
Sorry to hear that. I knew Duke well. How about Hank Dinger, is he still with us? He used to work the tower and did the "Competion Copyright".
I have not raced on Saturday. For a while so I do not know if Hank is still announcing for points races. The have been using a different announcer on Sunday events
