Uncle Bob
Shiny paint causes stress.
I took my car for a spin today, noticed the hydraulic lifters seemed noisier than usual, then when I came home and parked for a second to open the garage and restarted the car, there was a heck of a racket, and only 20 PSI oil pressure. I didn't notice it running rough or anything when I parked it, but sure did when I restarted it. I pulled it straight inside and shut it off.
Not knowing what else to do, I tore it down, and noticed that #1 exhaust lifter was bled off. The other lifters were solid. I kept going until I had the lifter in my hand and there's no damage on it. It just won't pump up and I guess it was bypassing all the oil causing the OP to drop.
So, I guess I need a new set of lifters. The engine might have 100 miles on it at most (Howard's lifters and cam). There has always been a lot of noise in the top end, so this doesn't surprise me.
Is just replacing the lifters the right thing to do? I really don't know what else I could do. Would I be able to at least see what went wrong if I take the lifter apart?
Also, what is the best brand of lifters right now? I thought Howard's was it, but maybe not.
A photo of the lifter's face is below. Nothing on it but dust. That was a relief. With my luck I expected to find at least one chewed but everything looks hunky dory in there.
Thanks for any advice.
