No, I actually use 1.65 HS rockers...I order them this way.So it's been my experience with Edelbrock style La heads that running a 1.6 rocker arm is not possible without enlarging the pushrod hole. My question is this also a issue for the Trick flow 190s.
Any clearance issues with 3/8" pushrods with that combo?No, I actually use 1.65 HS rockers...I order them this way.
I used the Mancini 1.6 rockers that are made by Harland Sharp on the Trick Flow 190 heads, they worked out pretty niceAny clearance issues with 3/8" pushrods with that combo?
How the sweep with the HS rockers and the TF heads?
Did you use 3/8" pushrods?I used the Mancini 1.6 rockers that are made by Harland Sharp on the Trick Flow 190 heads, they worked out pretty niceView attachment 1716417541View attachment 1716417542
Yes, Smith Bros 3/8 push rods, no clearance issues.Did you use 3/8" pushrods?
Thanks Brian.No, I actually use 1.65 HS rockers...I order them this way.
Sweep is decent, no clearance issues and yes 3/8.Any clearance issues with 3/8" pushrods with that combo?
