Trick flow 190 head clearance question
Dart Frog
Oregon
So it's been my experience with Edelbrock style La heads that running a 1.6 rocker arm is not possible without enlarging the pushrod hole. My question is this also a issue for the Trick flow 190s.
Any clearance issues with 3/8" pushrods with that combo?
How the sweep with the HS rockers and the TF heads?
I used the Mancini 1.6 rockers that are made by Harland Sharp on the Trick Flow 190 heads, they worked out pretty nice
