367 vs 410 Engines Masters
I'm not looking at peaks but the averages, When I compare engines that have different rpm power bands on the dyno graph, I compare hp horizontally to what rpm each engine makes that hp, eg, at what rpms do each engine make 250hp, 300hp, 350hp, 400hp, 422.hp etc..
I couldn't get a good read on the graph in the video but when you said it's only 8.5 hp more than the 360 those are the peak numbers. Unless I am remembering wrong. Not average numbers. When Abody wagon said it would be cheaper to build the 360 you replied "especially for a 8.5 hp difference." I thought that comparing only the peak hp difference was misrepresenting the complete difference between the two motors.
Torque is relatively flat (frown curve) especially compared to hp which has more of a hockey stick shape. So we know a high lbs-ft per cid that that's fairly flat over a broad range of rpm numbers = a good under the curve hp eg. it makes over 500 lbs-ft from 3000-5500 rpms, to say that in hp power you would have to rattle off a bunch of hp and rpm numbers and still be fuzzy, eg. 250 hp @ 3000 rpm, 300 hp @ 4000 rpm, 350 hp @ 5000 rpm etc..
The look on a customers face when he hears a big number tells me it's because we all like big numbers.
Never said that 8.5 hp was the average, just wrote that cause figure some aren't gonna watch the video so I included their findings.
When I'm comparing rpms that each engine makes X hp at, like shown below I'm accounting for the average.
Here's 318 that makes 425 hp @ 6,200 rpm, ported EQ's, airgap, 231/237 .525" 110.
(less cam better cyl head)
rpms @ hp for each cid 323 367 410
rpms @ 250hp 3,600 3,200 3,000
rpms @ 300hp 4,100 3,650 3,400
rpms @ 350hp 4,800 4,100 3,800
rpms @ 400hp 5,600 4,900 4,600
rpms @ 420hp 6,100 5,400 4,900
rpm @ peak hp 6,200 5,800 5,500
250hp to hp peak the 323/367 did it in a 2,600 rpm band, 410 = 2,500 rpm band they all are basically making similar average power just the rpms are different why they need different stall and gearing.
Chrysler 318 Engine - A Powerplant To Brag About
On The Dyno318 Mopar Street EngineSuperflow 901 Engine Dyno Stp Correction Factor Tested At Westech Performance Group
RPMTQTQHPHP
BASEPORTEDBASEPORTED
3,000335335192192
3,200342340208207
3,400351356228231
3,600365369250253
3,800374379271274
4,000379384289293
4,200378383302306
4,400375383314321
4,600376382329335
4,800375386343353
5,000372384354366
5,200367383363378
5,400361379371390
5,600355374379399
5,800350371386409
6,000345365395418
6,200341360402425
6,400329345401421
In the example of the two motors being compared on the engine masters video, the graph shows the two motors layed over the top of each other. It's clear that the 408 is making more power everywhere with the smallest difference being at or around peak hp. If we could read the graph well enough to get the horsepower numbers for each motor in 1000 rpm increments we could calculate the average horsepower for each engine. I'm pretty sure it will show that the 408 is making quite a bit more power than the 360. This is the conclusion that all three of the host on the show came to. They even joked about it saying in this case for the money spent on each engine that it didn't make sense for them to build the 360. This was their opinion not mine. It seems like their conclusion may have rubbed you the wrong way? Maybe you came to a different conclusion about which motor made more power based on the data they provided. We all like to root for the underdog or the example that goes against the "conventional wisdom". it looks like you are trying to cherry pick numbers from this test and use numbers from a different test to minimize the difference between the 408 and 360 in the engine masters test. In my opinion the engine masters test seems pretty conclusive. I not saying that a 360 can't beat a 406 or that there isn't another test under different conditions where the 360 is making more power but I don't see it in this test.
The bigger the cubes with heads commonly available for small block the better the truck engine. A trick set of cylinder heads is needed to make an honest 600+ HP small block in 408 cubes or more
But it's the same circumstance for the 367, 410/367 are just the static displacements, CFM is the actual displacement (dynamic displacement, cid x rpm), both are making similar power so there displacing similar amount of air/fuel over time (CFM). Heads intake etc.. doing a similar job for both.
I agree with you, but port the intake or port both intake and cylinder heads and I believe you would have two vasty different power curves although I'm not sure how those curves would compare or what they would look like exactly. I believe then the 367 would take what it wanted and the 410 would take what it really needed. What would really make a difference is different camshaft grinds specifically suited to each engine.
All in all when he started talking about the cost of rebalancing and grinding the 367 crankshaft compared to the stroker crankshaft kit, the choice is obvious.
Yes if you read the dyno graph that way obviously the 408 wins in all but the last couple hundred rpms. But what I'm talking about is just from a performance perspective not driveability or whatever other design requirements you may have that's got nothing to do with each engines potential, those are why you would choose one over the other or even build something entirely different.
I'm talking both in same chassis and weight and you gear and stall and shift for maximum 1/4 1/8 0-60 stop light to stop light or whatever other performance metric being used, if you factor in gearing, and stall to shift points (the powerband being used) If optimized for each your not gonna run the same stall gears and shift points if you look at the curves from that perspective on how they will function in the car (power to the ground) then it changes things.
Now obviously a lot wouldn't run optimal gearing etc.. probably put a set 3.55 behind both so yes in that case the 408 will have an advantage, why people generally build them they will need less gearing, stall, rpm (more street able) then a similar powered smaller engine. Which is fine and you could read the graph more like your doing but doesn't mean the larger one automatically has the performance advantage it's just you don't want to run the necessary gears and such.
Someone should go about it from the other angle.
Build the bigger cube version with enough head/intake/carb/cam/header to make good upper rpm power, in the 1.5+hp/ci range………..then put all that stuff on something with a noticeably shorter stroke………and see if it will peak high enough to keep up.
They may, but what I'm trying to say is everyone is generally unfairly comparing the two power curves say the 410 stall is 3,500 rpms and shifts at 6,000 rpm that's it's power curve being used, say the 367 stalls at 3,800 rpm and shifts at 6,300 rpms if overlap there curves from that perspective they would be a lot less different than people think.
I don't get that line of reasoning that to make this a fairer comparison the 410 needs higher hp parts, I see it as, if you wanted a 425 ish HP this is what the curves of a 410 367 323 could possibly be. Then you take your design requirements and preferences and choose what best fits you.
I bet moving around the opening and closing points for without moving up or down in duration much (level) each engine could be more optimized.
A lot would be better of with a 410 but it doesn't necessarily out perform (say in 1/4 mile) the 367 which is my point.
The problem with these comparison what's a fair way to do it ?
If your building say a 600-650 hp 305 (340) vs 416 your not gonna use the exact same parts since powerbands gonna be at vastly different rpms but once you start using different parts what's equivalent ?
“a given top end and cam package” will be more optimized for a particular displacement, better than something that strays too far up or down.
I’m just saying, let’s see one of these shootouts where the top end package is more suited for the bigger combo.
I get what you and others are saying, Ok let’s say we put on heads for a pump gas 410 that makes peak power at 7,000 rpm’s and pulls well to 7,500/7,700 rpm’s for good shift points, decently optimized.
Now you put them heads on the 367, there obviously not optimized for same rpm’s but no reason the 367 couldn’t pull similar hp just at a higher rpm and anything like these engines wouldn’t need too much more rpm.
That’s the problem I’m seeing it’s not like what ever heads you go to within reason (optimized?) that the 367 can’t use them either.
625hp/410ci = 1.52 hp/ci
625hp/367ci = 1.70 hp/ci
My side of the argument is based on years of engine building and dyno testing……..and that experience has shown me it’s not all that hard to make 1.52hp/ci, but it’s def not as easy to take the same parts that got you to that point, and now make 1.7hp/ci.
And that doing nothing to the combo except reducing the displacement doesn’t usually bridge that gap in efficiency.
Some numbers-
Real world results of a 12:1 540 BBM with ported -1 heads and a 281/293-112 roller cam with the Indy manifold and an 1150 on it.
805hp……1.49hp/ci
If you swapped in a stock stroke rotating assy, kept the same CR, and reused the rest of the entire top end(which are all parts that people regularly use on 440 builds)….to make 805hp the hp/ci would need to be 1.78…….which is noticeably higher than any 440-1 engine I’ve seen on the dyno.
Would they? I'm not sure about that. Plot it out for the 360 and the 406 used in the engine masters challenge. I think it will still favor the 406. And why wouldn't you use a 3800 rpm stall and gear and shift at 6300 with the 406?
Average HP 3500-6000 410=389
3800-6300 410=399.33
3500-6000 367=374.1
3800-6300 367=381.0
3500-6000 367=374.1
3800-6300 367=381.0
Those rpm's are off the top of my head as an example, point being the 367 should need to operate at a higher rpm's and should be accounted for. I'm not trying to make an argument for the 367 being better but should be compare more fairly, and done that way the difference are not as night and day.
Now if we we're comparing for a particular application then you'd use those parameters, but why compare them as if the 367 is gonna automatically be poorly geared. To me when we compare them in a general sense should be assume under optimized circumstances, but if for a particular application then yes use those parameters.
Here's easier example to show what I'm talking about, 400 vs 302 Ford. 400 Green 302 Red & Blue.
The both basically make same peak hp 264-267 @ 600 rpm's apart 4100 vs 4700 rpm.
150 hp about 700 rpm's apart, same with 200 hp, about 900 rpm's apart.
Above peak hp 302 basically making peak power still about 700 rpm's (5,400 rpm's) after peak.
So obviously the 302 is gonna want to operate 600-900 rpm's higher, to make the most out each the 302 would need higher stall and deeper gears so at any given mph the 302 will be operating at these higher rpm's so Ideally both would be putting similar hp to the ground.
But most see that 200 lbs-ft difference and both making practically same peak hp and figure the 302 is a goner. Yes if you ran less gear than the 302 needs would be harder to compete.
When you gear both for optimal performance that 200 lbs-ft will shrink by time you get to the torque to the ground.
I didn't said easy or same parts, just said same heads on a 367, I'm just saying the 367 should be built to a similar standard to be fairer. Problem is like I said earlier what is a similar standard when using different parts and even if using same parts, is that fair especially if both engines need to operate at vastly different rpm's.
To me the fairest is both be built to the same power, does one NEED (not built with) vastly different level of parts.
Some numbers-
805hp……1.49hp/ci
What do the 440's make ?
Hopefully at least 750 hp
If so I'd call that good for a (20%) 90 cid difference at that level making a 7.5% hp difference and at the street level 410 vs 367 a 12% making a 2% hp difference.
Wonder how much tweaking of cam specs, runner and header lengths maybe port volume etc.. to get to 805 hp.
The best stock stroke 440 I’ve seen here was 712hp.
For 805hp……..that’s a completely different build.
Keep in mind that particular 540 was a very basic bracket build with no trick parts.
Same basic cubes(542), higher end build with better heads was 860hp.
Now the 451” needs to be 1.9hp/ci to keep up.
Here's a video to make you 410 should of had a better heads, happy.
They swap on 1.6 roller rockers and single plane intake, basically killed the bottom end and made a new baselline of 438.7 hp @ 5,500 rpms & 448.2 tq @ 4,700 rpms, then ported out the heads and intake for a 92 hp and 900 rpm gain to the peak power for 530.8 hp @ 6,400 rpm & 488 tq @ 5,200 rpm, be nice to see same mods done to the 367 :)
I'm using your example, the test done on engine masters. And your example, the rpm difference between the two motors you used as the reason they would run about the same. Now you want to use a couple of fords instead? Shouldn't we stick with the original test that you posted. If you can't make your point with that test then it might not apply to that test. I feel like your going to just keep moving the goal post. I get what your saying but I don't see it in the test you posted.
Where are you getting 2%. Are you cherry picking the point in the curve where the two motors were the closest? Doesn't look like you're using average horsepower.
