You need to get 3.23 gears at least. Why have that power and torque and not be able to get the full benefit of it? Off line acceleration would be better
It's how I bought the car, it's actually not too bad, but like I pointed out it's relatively hard to get into the meat of the powerband 4000-6000 rpm = 40-60 ish mph in 1st, I'd think more like 3.73 or 3.91 gears if I'm gonna do it, 3.23 isn't much of a change 3.55 minimum.
I did this a while ago to see which gears look to work best, 3.91 look to be best but there's no converter slip factored in so, 3.73 with some slip look the best to me.
2.94 with 26" tires.
1st 2.45 = 896 rpm for every 10 mph
2nd 1.45 = 551 rpm for every 10 mph
3rd 1.00 = 380 rpm for every 10 mph
30 mph = 2,800 rpm, 40 mph = 3,724 rpm, 50 mph = 4,655 rpm, 60 mph = 5,586 rpm, 64.4 mph = 6,000 rpm.
64.4 mph = 3,548 rpm, 70 mph = 3,857 rpm, 80 mph = 4,408 rpm, 90 mph = 4,959 rpm, 100 mph = 5,510 rpm, 110 mph = 6,061 rpm
3.23 with 26" tires.
1st 2.45 = 1023 rpm for every 10 mph
2nd 1.45 = 605 rpm for every 10 mph
3rd 1.00 = 417 rpm for every 10 mph
27 mph = 2,800 rpm, 30 mph = 3,069 rpm, 40 mph = 4,092 rpm, 50 mph = 5,115 rpm, 59 mph = 6,036 rpm
59 mph = 3,570 rpm, 70 mph = 4,235 rpm, 80 mph = 4,840 rpm, 90 mph = 5,445 rpm, 99 mph = 5,990 rpm,
99 mph = 4,128 rpm, 110 mph = 4,587 rpm
3.55 with 26" tires.
1st 2.45 = 1,124 rpm for every 10 mph
2nd 1.45 = 665 rpm for every 10 mph
3rd 1.00 = 459 rpm for every 10 mph
25 mph = 2,800 rpm, 30 mph = 3,372 rpm, 40 mph = 4,496 rpm, 50 mph = 5,630 rpm, 53.3 mph = 6,000 rpm
53.3 mph = 3,544 rpm, 60 mph = 3,990 rpm, 70 mph = 4,655 rpm, 80 mph = 5,320, 90 mph = 5,985 rpm
90 mph = 4,131 rpm, 100 mph = 4,590 rpm, 110 mph = 5,049 rpm.
3.73 with 26" tires.
1st 2.45 = 1,181 rpm for every 10 mph
2nd 1.45 = 699 rpm for every 10 mph
3rd 1.00 = 482 rpm for every 10 mph
24 mph = 2,800 rpm, 30 mph = 3,543 rpm, 40 mph = 4,724 rpm, 50 mph = 5,905 rpm
50 mph = 3,495 rpm, 60 mph = 4,194 rpm, 70 mph = 4,893 rpm, 80 mph = 5,592, 86 mph = 6,011 rpm
86 mph = 4,131 rpm, 100 mph = 4,820 rpm, 110 mph = 5,302 rpm.
3.91 with 26" tires.
1st 2.45 1238 rpm for every 10 mph
2nd 1.45 733 rpm for every 10 mph
3rd 1.00 505 rpm for every 10 mph
23 mph = 2,800 rpm, 30 mph = 3,714 rpm, 40 mph = 4,952 rpm, 48 mph = 5,942 rpm
48 mph = 3,518 rpm, 60 mph = 4,398 rpm, 70 mph = 5,131 rpm, 82 mph = 6,011 rpm
82 mph = 4,141 rpm, 90 mph = 4,545 rpm, 100 mph = 5,050 rpm, 110 mph = 5,555 rpm
