Building a 408 cid for a 1974 Duster. I have built a few small block 340’s in the past and only had one issue with oil pressure. (Machine shop forgot to put the internal plug in by the distributor)
I went to start the new 408 and the oil pressure gauge never even budged. I bought an oil pressure test gauge and the same result.
Has anyone had the same issue of having zero oil pressure or have any suggestions on what to look for before I drop the pan and replace the oil pump or pull the engine?
