I have real world feedback to provide on TTI shorty headers as I installed them in my 340 Duster with 727. I used the TTI head pipes and their full 2.5” H pipe dual exhaust. I paid up and bought the ceramic coated version so they would always look good, and they did up until I cleaned fingerprints off them before running, and ran the car to break in the new lifters. Within a week of the car sitting in the garage the coating on the headers appeared to rust…. Therefore looking crappy… ugh. But before that I had issues with header fitment, mainly passenger side. TTI says it fits with the oil filter direct mounted to the block, which is true… if you use a short oil filter and wish to pull the header to change said oil filter. Since I had no 90 degree factory adapter and everyone wanted $100 for a rusty one at the time I did an oil filter relocation kit instead. So then on to the full exhaust, which I had to cut and modify to remove the offset that pushed the exhaust into wanting the same real estate as the original floors… ugh. Drivers side… I am running manual steering box and had column shift, and bought the TTI Z bar, which has fully length adjustable linkage… so between it and the original trans linkage being adjustable and the throw of the shifter, plus drilling additional hole in the TTI Z bar I never could get the gears to line up on the column indicator thru the full sweep… so I went out and bought a floor shifter to shift my automatic by cable. I didn’t even complain about the oversized muffler hangers that don’t have the right angle or fit how described, so I went out and bought cheaper clamp on strap hangers for the mufflers. At the back I used TTI frame hangers. Still to this day the tips are not lined up after yet more tweaking of the pipes. Does it sound good, yes. Does it look good, better than rusty Headman Headers. Fit is ok, but nothing to write home about. If I were to do it again I would save the money and avoid TTI. I don’t know what I would go with instead. Always heard TTI was the best, and one should pay for the best… I’d like to see second best I guess…
This was my personal experience and I never called TTI with my problems, as I didn’t want to waste time waiting for their solution. It seemed clear, cut and weld… the headers fit as they said and to return this stuff would kill in shipping cost, so instead of going to war… I went to work modifying things to work…
Entire project I learned one thing, nothing advertised to fit ever fits, and everything advertised as universal fit was way easier to work with because it wasn’t supposed to fit, so no expectations of that fitting, but it did…
I am still running the TTI shorties and full exhaust, no complaints now except due to the modifications required I have exhaust leaks I need to revisit but until then, the windows are always down anyway.
