carfreak6970
I been have an issue that I would like some help with. The car is a 68 Dodge Dart with a slant six that I had on the road since 2008, I put about 40,000 miles on it. It has been a fairly reliable car. Last week I go to start it and it does not start. The oil like comes on and kind of dims/flashed when I turned the key from on to start. With the key in the on position I jump the starter relay at the battery and solenoid terminals and it starts right up. I did the same thing after the gym to get to work that day. However, after work I went to start it with the key again and everything seemed fine. So instead of replacing parts I figured I would see if I could jump it from the signal side of the relay or ground it from the ground side to see if the problem was either in the ignition switch side or neutral start switch side when this issue would come about again. I drove the car every day last week.
Well I had the same issue this morning. So I removed the ignition switch wiring from the relay and jumped it with the positive post on the battery. It cranked over, but I forgot to have the key in the on position. So I reconnect the wire on the relay and try to start it with the key and she fires right up!
Now I am about 99% sure the car has its original wiring and ignition switch, but I am not to sure if I replaced the neutral start switch or the starter relay before. I do not have the maintenance log with me at work. Now I know electrical issues can come and go as they please, but when I checked the wiring out it appears to be in as good of shape as it can be for that age. Meaning no split insulation, frayed terminals etc.
So does this sound more like a relay issue? or an ignition switch issue? I have a spare relay in the box sitting on the shelf, should I just stop this foolishness, replace the relay and see what happens?
