Detroit Iron
I wish I could do things ONE f-ing time and be done, but no....
I rebuilt my 904... including the installation of a new tail shaft bushing. And.... I have a brand new Denny's drive shaft which has a brand new slip yoke.
I got everything put together and drove the car maybe 10 miles..... and there's a vibration at speeds above 40 mph. So I go under the car to make sure the u-joints are in the yoke properly, check pinion angle etc. and see ATF drips from the transmission tail shaft at the yoke. I grab the drive shaft, shove up and down, and there's play between the tail shaft and the slip yoke.
So I'd like input on a couple things.
1) How do you think this issue came about? Do tail shafts go bad? Was the bushing I used bad?
2) What's the best way to change the tail shaft bushing now that there's an output shaft in the center of it?
