Rotor Suggestions (I'm sure I am overthinking this)
MountainMan73
Active Member
Jasper, GA
Hey All new to the forum as of yesterday already learned a ton information thank you all! So I'm sure I'm making a mountain out of a mole hill but long story short. 69 Dart that was frame off by my father 20+ years ago before he passed in 2000. The car hasn't been drove much since maybe handful of times. Last time I drove it the brakes did not want to stop the car prob been 6+ years ago. So I'm going through the entire brake system. Took it apart yesterday and it does have the 73+ disc brake conversion. My question is I know the left side rotor was warped it would spin free then grab. Every part on this car is OEM all Chrysler stuff. Calipers, lines, rotors etc. Do I try to retain the OEM stuff or say the heck with it and bring it to the current part era and replace it all. What do you guys think?? Heres the post I made yesterday that has some pictures of the parts. Im still trying to figure out this whole forum thing lol! New Mopar Junky TIA!!!!!
I would stay OEM the new metal sucks. Have the rotors resurfaced.
This is what led me to my overthinking! I'm sure these rotors have been turned before is there a minimum thickness they need to be? That's what I'm currently researching lol. I do know the calipers are gone there's no getting around that there so rusty and gross I'm just not comfortable with them.
Welcome, go to mymopar.com There are downloadable free manuals. Get both a service and parts manual. That will give you your spec.
I would change as little as required to get running/driving/stopping. Calipers/rotors are plentiful for bbp. Chk Rock Auto and Summit, you can also call Dr. DIFF.
Should be cast into the outside hub if they are Mopar
I do not know your skill set but they are pretty easy to rebuild if the inside of the piston where the fluid goes is not pitted. Or
@mobileparts prob has nos ones.
Thank you for this!
Well update… The right rotor is .92-.93 and the left is anywhere from .97-.95 Stamped on rotor is .94 so looking like I am going to have to replace. Who is the best go to for good quality rotors
Look ar ricksmopars store on ebay. If he doesn't have it, he may tell you where you can get them. I know he has calipers, but they are pin type.
bendix and raybestos are still available and of reasonable quality. rock auto carries them as will a decent local joint.
How are you going to use the car? That is what determines if a brake upgrade is necessary. The 73+ stock brakes are great and handle stopping duties pretty well even for a hopped up street/strip car. Around 450hp and more strip than street I’d look to upgrade. Or if auto cross or road racing is planned
Not looking to really upgrade this is a numbers matching stock car. Has a 318 in it. Just looking to replace the original rotors calipers from the original conversion my father did.
Oh!!!! Theres no telling. When my father did it I was probably only 6-7 years old. I just remember walking into the garage one Sunday afternoon and he was covered in black paint where he had just got finished spraying the frame lol
there's no "frame" on our cars. they're unitized body construction. front subframe, rear subframe and sheetmetal in the middle.
so when somebody says "frame off" all the pedantry comes out...
You know what you are correct it shows my ignorance. It was a 57 chevy 210 car he was working as well. Now that Im thinking about it he did have the the k member I believe its called and some other suspension parts hanging up. I have a lot to learn!
Looking at the pic, the suspension pieces look pretty fresh, you said he re-did the front end, it seems so.
The calipers look rusty, but that's just cosmetics. The 2 things that count are the piston surface and seal.
Whether that caliper sat on a shelf for however many years, or is on the car, it should be fairly fresh.
The rotors can be turned, they appear fresh , find a machine shop to measure and machine as nec. Let them decide.
You got a nice car there, you're a lucky fella, - and you found the right place for help.
Don't be in a hurry to replace perfectly good stuff .
Good luck
I REALLY would not get too excited about min thickness on those girls. They have LOTS of meat and the pistons have lots of travel. You could easily DOUBLE the allowable cut and still be very, very safe. I have turned hundreds, if not thousands of drums and rotors in a previous life, all the way from little Fiats to over the road truck trailers. And I've relined shoes, and trailer brake shoes, and quite a few winch drums and such.
I know. I KNOW. It's the stated thickness. If this was a single width modern rotor, I would not go .001 under the spec
I still have an Ammco drum/ rotor machine. Turning the rotors, now 3 years ago, when I converted the diesel to 4WD
img_3777-jpg.1716005520
img_3779-jpg.1716005518
TBH I think thats exactly what I am going to do. Theres no way a few thousandths is going to make that big of a difference. I really want to keep the chrysler parts but don't think im going to get lucky with the calipers cause they are pretty nasty t say the least thanks for the input!
Good luck
Thanks for the advice! You are right along with my line of thinking. The calipers themselves have been gone through before there's some scratches and knicks on the piston and like you said the seals are all but shot.
