Hello all. Long time, no chat.
Life's demands are finally turning the corner since mandatory retirement last year, so maybe I can spend more time lurking online again.
Note to others. That "push through it - get over the pain latter" ethic us boomers were raised with will eventually bite you in the ***. The problem is in not finding out it doesn't work anymore until you don't recover...
Dolly the Dart continues to be a frequent three season diver up here in the Pacific NW with no more needed than oil changes and valve adjustments. Dolly gets runs around town and random trips to Mt Rainier and the Pacific Ocean. And the wife still gets that little grin when that crisp exhaust note comes in at 2700 RPM.
The turd in the punchbowl is cheaply made oil light switches. I'm on my third switch in 6000 miles. The oil light doesn't come on when the pressure switch starts leaking. It just starts leaving a trail of oil on the road behind the car. So far, the failures have been during local hops and I notice the oil trial coming up the driveway into the garage. The unnerving part of this issue is the light wouldn't come on until the switch dumps enough oil out to create low pressure. This doesn't exactly build confidence in spontaneous trips to remote areas.
The switch always leaks where the metal outer ring overlaps the plastic housing (pic). I've tried different auto parts stores, the last one being NAPA. This is feeling like the definition of insanity. I keep doing the same thing over and over, expecting a different solution! If all these switches are coming from the same lowest bidding manufacturer, what's left to do short of modifying one of these switches? JB Weld where the plastic meets the metal collar?
I thought about installing an aftermarket mechanical oil pressure gauge, but my wife barely recognizes the fuel gauge.
Thanks in advance for your thoughts. This car wouldn't be a driver without everyone on this site being open with their skills.
Note to others. That "push through it - get over the pain latter" ethic us boomers were raised with will eventually bite you in the ***. The problem is in not finding out it doesn't work anymore until you don't recover...Dolly the Dart continues to be a frequent three season diver up here in the Pacific NW with no more needed than oil changes and valve adjustments. Dolly gets runs around town and random trips to Mt Rainier and the Pacific Ocean. And the wife still gets that little grin when that crisp exhaust note comes in at 2700 RPM.
