I agree with everything so far, we'd need to know where you're at now and realistically you should be able to get decent alignment numbers out of the UCA's you already have.
That being said, you can definitely get more positive caster with a set of SPC's, and the fact that they're double adjustable makes setting the alignment quite a bit easier.
As for which is better, the GenI or GenII SPC's, that's a pretty fine point. Both are double adjustable, so either one should be more than capable of getting some pretty extreme alignment numbers. The GenII's with their forged construction look to be a more durable set up, with fewer bolted connections. Not sure how relevant that is because the UCA doesn't carry a ton of load. They also come with a 1/2" extended ball joint, which it seems like in most applications is going to give you a better caster/camber curve. They have an SPC ball joint, which is rebuildable etc but can only be had from SPC as far as I'm aware.
The GenI's have a couple extra connections built into their design, and they run a standard Mopar upper ball joint (the later LBJ for 73+). The adjuster is the entire UCA arm, so it's actually a little easier to get to than the GenII's because the adjuster is further away from the frame.
And of course the GenI's seem to be almost half the price of the GenII's, but they typically come without upper ball joints so that's an added cost.
I've been running the GenI's on my Duster for years now without any issues, and I run it around at -1° camber, +6.5° caster and 1/16" toe. With lots of adjustment to spare. I have a set of GenII's that will probably replace the Hotchkis UCA's on my Challenger when it goes back together
