John Trickler
Can someone please tell me which Edelbrock Head I have? Thanks!
Ok, thanks. I was trying to figure out what I had. Just did a valve clearance check with my build. KB 243 pistons, block decked .008 with a .518 lift cam and the valves barely dented my clay.Those are the "340" ones with an open chamber. There may be a few iterations based on installed spring from Edelbrock. Not my favorite, barf. 60179 was the part number on the early casting. When I get those they go to the surfacer and get rid of the the open chamber!
https://www.edelbrock.com/rpm-chrysler-340-cylinder-head-60179.html
There is usually a number stamped on the end of the head as well. I forget if they put the 6017 in them.
Given a choice buy the 60779 based closed chamber model. Since you have them, figure out how to make them work.
Time for a bigger cam!Ok, thanks. I was trying to figure out what I had. Just did a valve clearance check with my build. KB 243 pistons, block decked .008 with a .518 lift cam and the valves barely dented my clay.
Just so you know:Ok, thanks. I was trying to figure out what I had. Just did a valve clearance check with my build. KB 243 pistons, block decked .008 with a .518 lift cam and the valves barely dented my clay.
