canyncarvr
What type are the female connectors at the ballast? They are not Packards. They look like an average female spade except for the retainer pin.
...like the Baomain Female Spade Quick Splice Crimp Terminals on Amazon?
I looked through the connector links posted, got either bad links or connectors that don't match what I'm after.
This is a futuristic question. I have yet to get the OEM terminals OUT of the connector!
Why? One of the connectors gets a bit warm, indicative of a poor connection from wire to terminal. I want to replace 'em. Not hot..just a bit warm. Voltage at the coil is 8.4V. Everything works as it should. I just want to get rid of the 'warm' part.
Thanks.
Thanks.
Mattax 4th pic down was what I was talking about. The only time I've seen the style with the spring tongue is on heater/ac wires under dash.
