cb474
Active Member
I have a 1969 Dart with the original steel wheels. I was getting new tires and I don't know how many times I told them the spec for the lug nuts was 55 ft lbs of torque.
When they were done they claimed some of lug bolts on one wheel were slipping and they couldn't torque it enough. They tried to convince me on this basis that the holes in the wheels were also wearing out; that the lug nuts were worn out, because they shouldn't be conical shaped (i.e. flat where they seat into the wheel); and that I probably need all new wheels. This was a supposedly respectable tire shop that knew about old cars.
Anyway, when I got home I decided to take off the wheel in question to look at what it would take to replace the slipping lug bolts (see it they were swaged or not). The lug nuts were almost impossible to loosen. I had that wheel on and off a bunch of times when I was working on the brakes recently and I knew this was way too tight. I was using as a breaker bar one of those old torque wrenches with the needle that points to the torque level and I could see it was taking 80 to 90 ft lbs, before the lug nuts started to move. Also there were little shavings of metal that came off the wheels (or maybe the nuts) as I loosened the lug nuts, which I have never seen before when removing the wheels on this car.
When I put the wheel back on I torqued it properly and in fact none of the lug bolts slipped (which makes me think if it really was slipping, it was because they were over torquing it--but I don't even know at this point that I believe it was slipping).
So should I care that the other three wheels are probably also over torqued? Should I take them off and do it correctly? Or not worry about it until I have to take them off again?
