If the Lunati cam has a lumpy idle [ do you have specs? ], engine will want a LOT more than 14* of timing at idle. Could be 25-40*, depending on cam. What will that do? It will produce more HP at idle. The
extra hp will help carry the load that the fans impose on the electrical system & there will be less rpm drop going into gear. The idle
mixture [ screws ] should also be adjusted
with the trans in gear, NOT in neutral.
The correct procedure to get the
best idle timing is this: car idling, in gear, loosen dist clamp. Slowly turn dist CCW to advance the timing. Rpm will increase, idle will get smoother. keep going until you get
the highest rpm. Now check what the timing is. That is what your engine needs for best idle.
Note the 50* comment, below.
