I got a really good deal on my Eddy heads and with money saved had them worked over.Now some of us bought these heads BEFORE the RHS heads were available.If I were to purchase the RHS heads and have them P&P say a stage 2 job,then shipped to Ontario,Canada,paying shipping,border fees,taxes..etc..I,m still ahead with the eddy,s and the weight savings for a race car.Not everybody on this site lives nextdoor to Brian at IMM.Just my opinion with price ranges on getting the RHS heads delivered done.:read2::-D
[[[There are guys that run eddelbrock heads and then there are guyz like stroked340 who run eddelbrock heads.
the diff between stroked340 and them is they are good guys that know it can be done different ways and it doesn't take big $$$$ and aluminum to do it...it was there choice and rightfully so..
while stroked340 gos on every thread and barfs out eddelcrock the best!]]]
eddy heads are great, but I can get more CFM/HP 'for the money' in RHS heads ,and to a point, jheads.
if it was cheaper to get eddlebrocks, I would too !
...why not right?
I'd also run 11.2 with a tighter center line/diff cam to take advantage of the heat disapation.
Of corse that just changed my build and cost me more money because see I already have all my parts, but some build around their heads,cams, all kinds of things... it equals the same in the end if you do it right..jst thinking out loud here but thats the whole point...isn't it? a matched combo?
I mean if your going to dump 1400$ into aluminum head, aren't you gonna take advantage of it and make your money count=POWER..?
So bump up the cylinder psi, and run a cam that lifts where those eddy heads really flow the 'slighted' numbers they say...right?
they seem to peak around 550/600 lift ootb
which with a flayt tappet you'll wanna go a lil over for the lag time/exaggeration of the fatter lower lift flow due to having more lift time during the opening and closing than the peak lift OR to make it last.... roller cam time if you want longevity out of 600+ lift.
Reminds me of the old 'bigger is better' cam saga...why is it so sluggish off idle? why isn't it faster? you mean I need all these other things like gears??
the aluminum...600 lift flow....and $1400 price tag is not gonna help when you only run a .500 lift cam with 9.5.-10.1 comp meanwhile the guy in the next lane is running the same 10.1, .500 lift cam, ported iron heads that touch 260cfm before .500 lift
So I'll say this to you guys with the eddys, you better really do it and not fk around, make those dollars count cause I'll be out there in the other lane looking for it.8)
