1/4 Mile Times
roccodart440
Doing a little bit of math. I you could get your slant six A Body down to 2800 pounds and spray it with 150 shot of N02 it should hit the high twelves or low 13's. Seems a little optimistic to me but even if you could get it into the 14's that is a really respectable stret car.
For those of you that have raced your /6's what times and with what setup/hp have you turned?
Curious.
260 wheel hp and 2800 pounds should equal 12.9 seconds.
To save everyone the 6 page read
***9 Second Zone***
9.85 @ ??? The Drakes, 1938 Simca
9.93 at 132 Charles Myers, Plymouth Arrow, 6/21/2003
9.97 @ ??? Cox Bros, 66 Dart
***10 Second Zone***
10.19 @ 129 Mike Jeffrey and Blaine Mueller's "Buzzin' Half Duzzin' 1968 Valiant
10.5 @ 127 Will 67 Barracuda methonal & nitrous with Cam2 enrichment July 2004
10.900 @ 124.24 - 1.57 60', turbo66valiant, 66 Valiant Signet, 2750# w/o driver, turbo, intercooled, 727, 2.94, AV gas, May '09.
***11 Second Zone***
11.529 @ 112.34, 1.53 60', Exner Geek, 62 Valiant, 2300#, 904, 4.56, Webers, on gas, Nov. 2007
11.54 Dave Mueller Alchohol Injected (C/Alcohol Record)
11.77 @ 116.29 Shaker223, 1.83 60', Stock Slant 6 with turbo, 1970 Swinger, 2.76 gear, 215/75R/14 radials, 3500lbs Oct 2009
11.88 Ron Hamby at Hamilton Oh. 2004 '66 Dart on NOS
11.970 @ 109.89 Guzzi Mark, Vegas 2010
11.98@109 turboram (Nick Stamm) 3600# 86 ram missing like heck!!
***12 Second Zone***
12:001 @ 110.07, 1.61 60', Slantzilla, '66 Valiant post car, 232 ci Slant, Keith Long full manual 904, 3.91, 150 Top Gun shot, 3250#, Street legal.
12.02@ 107mph Ron Hamby at ClayCity Ky. 2008 '66 Dart on Alky---
12.33 at 107.88, Samoa, SwinginSixAric
12.43 @ 102 mph at Clay City 10- 10- 09 Ron Parker
12.77 @ 105, Doctor Dodge - 62 Lancer, MATS 2009
12.941 @ 105.50, Old6rodder (Dick Sappington), HA/GR, "Barn Job #18", ANRA finals '09
12.98 at 101.03 at Redding, "Wayne's World" 170 cu inch (on gas) 62' Valiant -Wayne Erickson-
***13 Second Zone***
13.37 @ 98.33 Charrlie Schmid, 66 Cuda 170cid
13.39@96 sgtmcd42, Crooked 6, red light lifted @ 1000'
13.58@100 Kidd 62 Valiant, MATS 2009
13.41@ 96.20 Charrlie Schmid, 66 Valiant 225cid
13.76 @ 99.41, 1.90 60', Exner Geek, 62 Valiant, Street Driven, 2800#, A833OD 3.73 gas, June 2008
***14 Second Zone***
14.15 @ 91.02 Crazy Dart (converted from 1/8mi) 67 Dart,904, 3500 stall, 4.30 gear. 5500 RPM.
14.206 @ 94.76mph 2.05 60' METALSKIN draw thru turbo slant (9psi) AP5 valiant 2.9
14.30 @ 96 MPH Lou Madsen '64 Dart 270 in street/strip trim in 1997 at Pomona Dragway (904w/3400 stall, 14" Radial TAs, 60 over cast pistons)
14.57 @ 94.6 MPH, Lou Madsen '64 Dart 270 in street/roadrace trim, 2009 at Mason-Dixon Dragway (T5 trans, 16" autoX tires, 60 over cast pistons)
14.743 @ 89.81, 1.931 60' Bren67Cuda904, 258 ci Slant (Eileen) 3400 lbs with A/C, Gear Vendors, Full interior including Child car seat, 8 1/4, 3.55
14.79 @ 93.56 Greg Ondayko
14.84 @ 91.22 Ryan Covalt 72 Swinger 3170#/ w/o Driver, Mason Dixon
May 31,2009 1st time out. 4.30's, 4 sp.OD, street slicks
14:91@88-Little Red Piggie on muscle only-US41 8/29/09
14.975 @ 89.70mph "6 Pac To Go" Fopar's Mopar '63 Dart GT Woodburn 7/19/09
***15 Second Zone***
15.12 sergio 7/11/9 samoa stock engine 3.91 hedder ,5002 BB converter
15.20 @89 Joel Harris 69 Valiant, 225 stock bottom end, .100 off head, 2bbl, pump gas, mopar268 cam, headers, stall, 3.91, 904, 2750# w/o driver, mostly stock driver
15.34 @ ?? Brian '74 Duster,1971 225 block ,.100 off blk, .100 off head,MP 528" lift cam with 284 duration, 904,4.10
15.39 @ 87.32 Fopar May/4/08 3400lb 53 Ford 225 bored .030 .090 off head custom cam custom headers 904/4.11's
15.40 @ 89 mph Lindross, roadster
15.501 @ 88.32, SV162, low comp head, 3.7 diff, May 2008
15.73 @ 88.32, SV162, high comp head, 2.92 diff, Sept 2009
15.6 @ 90 MPH - '68 Dart street car - Lou Madsen - 1996 at LA Cty Raceway
15.66 @ 87.87, Ceej, Hooptie, Woodburn 7/19/09
15.82 @ 84.0, Lou Madsen (Dart270) '90 Slantkota with 258" engine, mild cam, 2.76 gear, 2300 stall, no carb/ign tuning yet, Clay City, KY, 10/10/09
15.82 @ 84.32 1974Duster Kev- Converted from 1/8 mile numbers
15.855 @ 87.25, Rob Simmons, '73 "GodsRods" Duster, 28 May 06 @ SGMP, just under 2,785 #
***16 Second Zone***
16.18 @ 84.26, SV162, low comp head, 2.92 diff, Feb 2009
16.281 @ 82.64 DusterIdiot, Medford, Hpak Duster Holley Annular 600, 3400 lbs
16.35 @ 81.3 70valiant', 3.23
16.59 at 81.68mph TRYSIX '65 Coronet 4dr, Isky cam 228/448
16.707 @ 82.11 Mike Andreas,225 cid block +30. Stock pistons .100 off the deck. Isky 448 lift, 4 speed
16.868, 80.06 MPH J. Skinner '67 Valiant 100 3-speed, stock short block
16.89 @ 78.49 3.23open 75 duster (Wicked/six)
***17 Second Zone***
17.03 @81 MPH. Casey Reed R688 '70 Dart 225/904, 4-BBL, headers. 2.76 open.
17.20 @ 85 The Black Sheep
17.27 @ 79.03 Featherduster76(converted from 1/8mi) 71 Duster 225/904
17.29 @ 78.66 Rhonda Amis '66 Valiant Signet 200 225ci,904 MATS 2009
17.44@78 Slant Cecil '68 Signet 225, 904 ,2975lb w/driver ,140K mile motor with 6x1 header, BBD, electronic ign ,4400rpm shift
17.58 @ 81.85 aaron downing 225, 904, highway gears
17.72@77 Nick Bowman 1970 Plymouth Duster 2bbl-904-3.23
***18 Second Zone***
18.312 @ 72.31 Vallyant
18.705 @ 73.41 The Hard Way '74 Dart 4 Door 198 Auto
18.832 @ 72.82 Dodgegirl
18.766 @ 70.69 Mike'68Dart, Aug 28, 2009
***19 Second Zone***
19.05 @ 73 Davids63Dart, September 2007
19.21 @ 70 Doc, 65 Dart GT Convertible, stock alm block 225 ,1bbl Carter, Dutra dual exhaust, 904 auto. trans., 2.94 8 3/4 rearend.
19.35 @ 69.85 THOR, '74 Swinger, Redding Dragstrip (Stock Cast crank-juice engine... stock 2.76:1 "SG") 10/25/08
19.37 @ 69.77 Aggressive Ted, '74 Swinger, Pacific Raceways
19.52 @ 69.26 Slanted66, Altitude 5300 ft (Headers, Isky cam, 1bbl, 904, 3.23s)
19.6 @ 71 eightymopar , 1980 Cordoba
19.78 @69.56 1980volare, 1980 volare,bbd 2.76,28" tires,stock exhaust.
***20 second Zone***
22.18 @ 60.6mph 72polara, '73 /6 Swinger stock and wore out
hey theres me. 17.58 thats with 500 miles on the car, just testing everything out. oh and it turns out i had 2:71 rear gears at the time. i wasnt even hitting third gear. hopefully i will make it to the track this weekend with my 3:55's and new carb.
I'm #1 in the 12 second section. Duplicate my build at 2800# and you'll be in the mid 11's.
congrats slantzilla. that must be fun. i have to keep mine somewhat stock and streetable. i dont have a heater or wipers, but i do have front and rear seats, and maybe one day carpet. i will be happy with 15's, maybe once the head is done....
where do u think all be with a 68 dart 3000 lbs.
3.91 SG and a 904 manual reverse VB
9.5 comp .510 cam heavily ported head, 600dp on massaged clifford manifold and hooker super comp headers?
light dyno pull showed 180hp and 250tq before tuning
you have a really good looking wagon .are you going to fremont on the 7th?
Lose 600lbs for starters,if you want to do it on all motor.I ran 13.009 all motor with simalar build at 2500lbs.Car now is 2400 lbs with me in it and runs in the 11s with new motor.Guzzi Mark
Oh come on! Why am I not on the 20 second list??? :thebirdm:
haha when i first started racing my stock 225 it ran a 20.20! haha. i got it down to 18.5 with no mods cann't wait to see with the new set up!
im getting a 72 z for a daily driver so i can go more extreme on the dart. so besides glass parts and stripping it, what are ur other tricks?
take out the regulators and put straps for the windows. take our rear seat. light weight battery if you really want to start shaving every lb
yep i was thinking of this also!
hey! what about going to homedepot and buying some sheets of lexan big enough for a side window for about 12 bucks??
