71 Duster weights 2950 with driver. 365 cu inches..
10.65 @ 123.22
gear 4.56 with 10 x 29 Hoosier slicks.
wallace calculator say 441 hp...
What has been down to engine
So your thinking about 440 hp?
1969 Cuda, stock 440-6pk motor, stock 906's, int/850DP/2" hdrs., .650" solid flat tappet, 3000lbs all in, 11.3@118.
Same set up with just 2.14/1.81 906's bolted on, approx (255cfm), 10.7@125
.030 over 360, 11.10 sec, 120 mph. 3030 with me in it, 4.56 gear, 28x9x15 Hoosiers, Wallace says 385 hp at the tires
69 Dart street/strip, 3260#, pump gas 408, Edelbrock heads, victor intake 950HP, Hughes 260/264 @ .050", .628/.633" flat solid, 10.9-1 cpmpression, 727, 9.5" converter that flashed 5000, 4.10 Strange S60 on 325 radials. Best runs were 6.57 @ 108 with a 1.38 60', it ran 6.70 with a 1.40 60' in street trim. I don't know the HP.
Great question also some what answered here -> http://www.forabodiesonly.com/mopar/showthread.php?t=87672 & http://www.forabodiesonly.com/mopar/showthread.php?t=8884810-11 second combos with hp weight gear ratio thanks
My dart runs high 12's, 3300 lbs, best guess is 350 or so hp. 340, stock forged replacement pistons, stock X heads, air gap, 750DP with pro form main body, cheap headers, old MP solid circle track cam, 238@50, around 480 lift after lash. 3800 stall 727 with 4.10 rear gears. Ran 12.8@105 with a 26 inch tall drag radial in good air.
Your .9 shy of being here, you go to slow for the request.:banghead:
