15x10 Small Bolt Pattern Aluminum Slots?
71GSSDemon
WI
Does anyone know of 15x10 or larger aluminum slot mags in small bolt pattern? I am not sure I have ever seen any. Thanks.
I have a set of 15x3.5 slots, just wondering if they also made the rear wide ones to go with them. Likely a large pattern rear axle and wheel?
I had a set of Shelby 15x8 or 10 slots in 5 on 4. Bought them from a member here, didn't fit my 65 Barracudas fenders.
Yes about a decade ago.....
Well, I know they made them now, so thank you!
THAT my friend is perfection! It SCREAMS 70's. And that grill :thumbsup: Icing on the cake.
thanks
i do love the way they looks
its crazy though, how much better the newer tires are...shes a little squirrelly with the N50s on
thanks
What size newer tires did you put on? Pics with those?
I would love to have the ProStock look, like Tennessee Thunder. I wonder what size tire, wheel, and backspacing it would take to pull that off?
a lot of that is in the shocks as well
since the tires are outside of the wheel wells you need to have the back end up high enough to clear them when the suspension compresses
if you want ill sell you the 14X10s, but good luck finding N50s that arent 30 years old
Yes I realize all the suspension issues to address. Just my favorite look.
Thanks, but I would rather have 15's. And N50-15s are still available.
Yeah I don't blame you...there's a reason I went with the 15x8s I'm running now
But nothing screams "HOTROD" harder then foot wife tires with an inch or two sticking out
