Wyrmrider
you can use hylomar on wet bolt threads
it can be re-torqued
So do you still have the head gaskets? It's conceivable that the coolant leaked past the head gasket and into that oil passage, but I'd expect to have found some wetness around the head gasket in that area or a distinct channel in the head gasket there.Rigth side Cylinder head went to the shop. Pressure tested perfect. Flatness....not so much. .004 warped! Its getting a light cut. I should have it back next week.
I'm going to pull the left head and get that checked out too, while most everything is broken down. Pressure test and cut if needed.
I cleaned and scotch padded the deck and wiped with brakekleen and looked VERY close....no visible cracks. so i hope...no cracks. The heads are early 70s. the block is 84
Which is what would accumulate in the sump and separate out.Which is why I said to crack the drainplug. If no coolant there then of course my idea is without merit.Did you check the video in post #18 AJ? Sorta looks like fresh coolant out of the rocker oiling hole.
It's the FABO way LOL!I thought about that but posted it anyway.
Fully warmed up...it should fire 1s or 2nd revolution. Pump the pedal once if it's coldNothing comes to mind about the slower start versus timing; could be a lot of things. But it is a moot point anyway as that is not the way carb'd engine work when cold.... and it is not clear from the posts if it IS cold starting that is slow....
FWIW: Not touching the accelerator prior to cold starting makes no sense whatsover.... this is not fuel injected. A carb'd engine will never start instantly when cold with no action on the operator's part; the carb needs at least 1 pump of the accelerator when cold just to engage the choke. Try pumping accelerator pedal to floor 2x and release after each pump, prior to cranking, and see what happens.
Hot starting should be very quick if all is right and the fuel is not boiling out of the carb..... which apparently is not uncommon with the Edelbrock carbs..
No sealer on those rocker shaft bolts,and don't use the factory spec torque which is for 3/8 bolts! IIRC they are just 5/16 bolts and the spec is 15 ftlbs lightly oiled. Lemmee check; hyup 15# for 5/16 it is.both heads back from the shop. both leak tested fine, no problem. each needed a .006 worth of cutting to get them flat. These are early 70s heads that are NOT original to this 84 block. 84 block was rebuilt at one time. heads were never cut before.
Heads going back on with sealant on the long bolts. Hoping for the best. If it happens again, I have 67 318 runner that will go in until I get the block sorted out. wish me luck.
Hot start needs some pedal too.I should be more clear...sorry. Once warm and running....I shut it down. wthing a minute, I turn the key - -its should start with NO throttle, just on the idle circuit. nice quick start.
I now have it doing that. I know that you need your foot in it, for setting the choke and some fuel introduced .
final setting: 13 degree initial mechanical timing, 36 total timing (mechanical). bell attached to ported vacuum - - getting another 5 -7 degrees. (can adjust for more) at 15 vac. Running nicely now.
I'm running a 1/2" termal insulator under the eddy carb on the manifold. Highly recomended
I imagine the OP is thinking that this will keep the coolant at bay if there is a crack or pin hole from the head bolt threads in block into the cooling jacket. But you're right AJ.. it very well is going to get into or restrict/block the rockers' oiling passage. And, besides, I'd rather see the problem show up again NOW at idle or sitting still, rather than be driving and having the pressurized coolant eventually get past the sealer unobserved (which it very probably will do) and then get into the oil, and damage every moving part: rockers, crank, rods, oil pump, etc.No sealer on those rocker shaft bolts,and don't use the factory spec torque which is for 3/8 bolts! IIRC they are just 5/16 bolts and the spec is 15 ftlbs lightly oiled. Lemmee check; hyup 15# for 5/16 it is.
No sealer on the headbolts either. How's the oil supposed to get into the rocker shafts if you plug the passage with sealer? And if by some miracle it washes up into the tubes, then what if it gets stuck in one of the rocker oiling holes? No sealer.
Let's see, does that passage go to the cam bearings?UPDATE: Both cylinder heads off to the machine shop. both cut ~ .005 for flatness. both leakchecked good. Assembled it up....ran it.....same problem. Leaking coolant into oil
Same place too, same side. Removed the right valve cover and rocker shaft. Pressurized the cooling system through the radiator. LOTS of coolant coming up the oiling tower into the rockershaft.
Now; leak definitely the block side. coolant getting into "cam to rocker" passage in the block.
Thinking of: drilling and sleeving the oil passage. ahhhh. so much fun.........
