PocketAces
Carquest store ordered the kit for my AFB #4305S. The new needle seats in the kit were slightly taller than the originals ( Took quite a while to discover this little difference ). With the needles closed and the float paralell with the top the float wouldn't drop far enough to open the gate. Adjusted to open right put the fuel level too high at gate closed. Some fancy tang bending was required to make them work right. I had to trim the slosh baffle in the bowl a little also.
May not be relevant to yours but couldn't hurt to double check, compare the new seats to those removed. Good luck with it.
My seats were the same height as the originals. I don't understand your post. You bend the float in two different places to affect the float level versus the float drop. Bend it where it attaches to the hollow portion to set the level. Bend the little tab to affect the drop.
