1965 Dodge Dart Charger convertible
Members Restorations
  1. 65dartcharger
    65dartcharger Dart Charger 273 Historian FABO Gold Member
    6,981
    2025
    Dec 9, 2006
    Tavelsjo, Sweden
    Local Time:
    4:24 AM
    Thank you! That would be great, I can get a better shot on the article tomorrow. I might have his phone number too. I post it tomorrow. Thanks again!
  2. 65dartcharger
    6,981
    2025
    Dec 9, 2006
    Tavelsjo, Sweden
    Local Time:
    4:24 AM
    After glass beading bolts and nuts it feels closer to the last assembly. Tonight I was able to do the blackout behind the grille.
    Love progress!
    • Like Like x 1
    • 65dartcharger
      6,981
      2025
      Dec 9, 2006
      Tavelsjo, Sweden
      Local Time:
      4:24 AM
      Yesterday I hocked up all the air condition stuff under the dash. I even glass beaded the springs holding the fuses so they will contact better. When I started to adjust the a/c cable I found out that I only have two of four spring washers holding the wires in place. (Actually I don't know the name but I hope you can tell by the picture) I need two of those so I can finish the wire and mount the glove box.
      • Like Like x 1
      • 65dartcharger
        6,981
        2025
        Dec 9, 2006
        Tavelsjo, Sweden
        Local Time:
        4:24 AM
        Lots of progress was made today. Left side lower and upper control arm mounted. Front shocks monted as well as the steering column. Left side torsion bar mounted and adjusted. All the heater hoses are in place with factory style corbin clamps including the upper radiator hose. I need to get a factory style battery for it.
        Found one wire with no address. It might be to the a/c but I connected two of the prongs together earlier. I might hook it up there. That's the only place I can think of.
        I really like how the carpet meets the firewall insulationtoo. No yellow paint from the floor.
        Tomorrow the a/c outlet will be added and then restore the left air door. Of cause some one before have opened the door so the hinges broke.
        I could have supported the ealier owners since 1965 with WD40! That would have help the door hinges!!
        • Like Like x 6
        • toolmanmike
          toolmanmike FABO MODERATOR Staff Member FABO Gold Member
          54,165
          39903
          Jan 18, 2006
          Iowa
          Local Time:
          9:24 PM
          She's a beauty Ulf. Nicely done!
          • Like Like x 1
          • Agree Agree x 1
          • Yunick13
            Yunick13 Well-Known Member
            1,630
            3441
            Sep 7, 2019
            No longer here.
            Local Time:
            9:24 PM
            Looks good.:thumbsup:
            • Like Like x 1
            • Agree Agree x 1
            • 65dartcharger
              6,981
              2025
              Dec 9, 2006
              Tavelsjo, Sweden
              Local Time:
              4:24 AM
              Next step is done. Interior completed so electrical check will start tomorrow.
              • Like Like x 5
              • 65dartcharger
                6,981
                2025
                Dec 9, 2006
                Tavelsjo, Sweden
                Local Time:
                4:24 AM
                This electrical check vent ok .
                BUT, when I swich the key to ignition the wipers come on. If I ground the outcome prong on the turn signal relay the turn signal works!
                I have switched the windshield wiper switch, wiper motor, ignition switch and turn signal relay but nothing helps.
                So after 4 hours of reading the blue print for the under dash wiring I decided to ask FABO. Has anyone had this trouble before. I'm suspecting the turn signal switch but not sure!
                Any help is very much appriciated.
              • 65dartcharger
                6,981
                2025
                Dec 9, 2006
                Tavelsjo, Sweden
                Local Time:
                4:24 AM
              • 65dartcharger
                6,981
                2025
                Dec 9, 2006
                Tavelsjo, Sweden
                Local Time:
                4:24 AM
                Frond end bolts and nuts tightened, front alignment adjusted, cotter pins mounted, shocks tightened, all vacuum lines hooked up. I even found an nice factory Bendix check valve to mount between rhe brake booster and the intake manifold. As a spare I have an NOS one too!
                Next will be to tighten the carb and check all fuel lines and we are ready to take her for a spin!! Can hardly wait!
                • Like Like x 4
                • toolmanmike
                  54,165
                  39903
                  Jan 18, 2006
                  Iowa
                  Local Time:
                  9:24 PM
                  She's a beauty Ulf.
                  • Like Like x 1
                  • 65dartcharger
                    6,981
                    2025
                    Dec 9, 2006
                    Tavelsjo, Sweden
                    Local Time:
                    4:24 AM
                    Thanks TMM! Now she is finally running.
                    Next is to mount the datecoded exhaust system!
                    • Like Like x 3
                    • 65dartcharger
                      6,981
                      2025
                      Dec 9, 2006
                      Tavelsjo, Sweden
                      Local Time:
                      4:24 AM
                      When you assemble a car with NOS stuff you get a result like this. Actually the pipe over th rear end is from Accurate it works great.
                      • Like Like x 1
                      • 65 Dartman
                        65 Dartman FABO Gold Member FABO Gold Member
                        11,760
                        3305
                        Sep 24, 2006
                        Strasburg, VA
                        Local Time:
                        10:24 PM
                        I ended up posting my thoughts about you electrical issue in our thread - Meeting in Rovanemi. Guess you missed it.
                      • 65dartcharger
                        6,981
                        2025
                        Dec 9, 2006
                        Tavelsjo, Sweden
                        Local Time:
                        4:24 AM
                        Yesterday I was able to take the convertible for a 10 mile trip. Can wait until next summer. But I was able to get a picture of the two of them.
                        • Like Like x 8
                        • toolmanmike
                          54,165
                          39903
                          Jan 18, 2006
                          Iowa
                          Local Time:
                          9:24 PM
                          • Agree Agree x 1
                          • KosmicKuda
                            KosmicKuda FABO Gold Member FABO Gold Member
                            1,850
                            633
                            Jan 15, 2011
                            N Ohio
                            Local Time:
                            10:24 PM
                            That's great Ulf! R eff minds ne of my 64 Valiant convertible. Got it running 3 years ago this month. Just in time for winter.
                            • Like Like x 1
                            • 65dartcharger
                              6,981
                              2025
                              Dec 9, 2006
                              Tavelsjo, Sweden
                              Local Time:
                              4:24 AM
                              Before a put them in the shop for the winter i had the opertunity to picture all of them.
                              • Like Like x 8
                              • 65dartcharger
                                6,981
                                2025
                                Dec 9, 2006
                                Tavelsjo, Sweden
                                Local Time:
                                4:24 AM
                                We had a Corona free cruise last night in town. 700 cars drove around for 6 hours. The big thing was that all folks stayed in the car so nothing was spread and it worked!
                                We had a great time. And for the first time in probably 50 years there were two factory Dart Charger 273s on the same cruise. We had a blast! Me and my wife took the convertible and our buddy Johan took the latest hardtop.
                                • Like Like x 7
                                • toolmanmike
                                  54,165
                                  39903
                                  Jan 18, 2006
                                  Iowa
                                  Local Time:
                                  9:24 PM
                                  Looks like you kids were having great fun.
                                  • Agree Agree x 2
                                  • 65ChargerDart
                                    65ChargerDart 65ChargerDart FABO Gold Member
                                    379
                                    162
                                    Jun 25, 2005
                                    Fortson, GA
                                    Local Time:
                                    10:24 PM
                                    I wonder why Chrysler placed the resonator notch in the rear valance of 273-4 Bbl Darts and Barracudas. The exhaust doesn't fit tightly into the notch. Maybe it was a miscalculation on the part of the designers and the exhaust extension was originally supposed to fit up into the notch?
                                    • Agree Agree x 2
                                    • Like Like x 1
                                    • 65dartcharger
                                      6,981
                                      2025
                                      Dec 9, 2006
                                      Tavelsjo, Sweden
                                      Local Time:
                                      4:24 AM
                                      Jim! I totally agree with you. But after hours of searching and thinking, the only thing I can come up with is that they used power tools.
                                      They hanged the complete system and then started to tighten the bolts from the back and moved forward. Before that they mounted the rear rubber bracket and the rear steel bracket above the rear end.
                                      The notch needed to be so much open to accomondate a power tool to bolt the resonator to the rubber bracket.
                                      That is the only thing I can come up with.
                                    • Avispa
                                      Avispa FABO Gold Member FABO Gold Member
                                      1,412
                                      854
                                      Feb 26, 2007
                                      Georgia
                                      Local Time:
                                      10:24 PM
                                      maybe the tip is upside down,maybe, maybe not
                                    • 65ChargerDart
                                      379
                                      162
                                      Jun 25, 2005
                                      Fortson, GA
                                      Local Time:
                                      10:24 PM
                                      I can assure you the exhaust tip on any of Ulf Andersen's cars is going to be fitted correctly!
                                      • Agree Agree x 1
                                      • 65ChargerDart
                                        379
                                        162
                                        Jun 25, 2005
                                        Fortson, GA
                                        Local Time:
                                        10:24 PM
                                        You may be right, Ulf but the hanger is the same on the '66 models without the notch and there is a bumper in the way, although the exhaust may have been attached before the bumper. I prefer to think there was a miscommunication between the engineering and design teams. It would have looked much better tucked up into the notch in the rear valance.
                                        When I had my 1st '65 Dart back in 1966 people would ask me why my exhaust tip hung too low. I asked the dealership and they told me that's the way they all came and it was supposed to hang down like that. I just accepted it but didn't think it looked right then and it still doesn't to me, especially when you look at how nicely the Mustang GT exhaust trumpets of the same era fit through their rear valance.
                                        I guess we'll never know... :)
