1966 Dart D-Dart cam spec
That Isky cam will make ur 273 so sad that it will make u want to cry if u even think of taking ur car for a drive. Contact 4spdragtop, he had the Comp 270 in a 273, I believe he has taken it out. He can give u some insight. I love the choppy sound even now but I have the reduced drive ability of a tiny engine with a big cam. Kim
You've been given MANY good recommendations and you keep asking for more.
I appreciate everyone's input, I am just trying to find a cam that will perform and have some kind of sound profile, I don't plan on driving the car much outside of town, it is just a street machine and if I want to go fast, I have other cars that will serve that purpose. I just want my Dart to sound good and perform better than it does. That little E-2 I have is just terrible, sounds like a sewing machine and I just can't live with that. If anyone has a good recommendation on what cam to get, I would appreciate or otherwise I am gonna buy this cam: SB Chrysler Performance Flat Tappet Cam & Lifter Kit - 286°/294°, 242°/246°@ | USA Performance Parts
Have Isky grind that custom one, or have my buddy Don Johansen grind me a true D-Dart cam.
On the rear end gears, I know a 3.91 is gonna be steep with the 3.09 first gear in the 4 speed, but they were affordable and are for the 741 case in my early B-Body rear end in my Dart.
here are the specs on the cam I had in my first 273 with the low compression pistons ........ pretty much the same cam , different number though >>> 1m286y advertised duration 286* - 510 lift . similar specs to the D-dart 273
Part No.: E420721
Grind: HI FLOW I M
SOLID
107 Lobe Separation Angle
Overlap: 72.00
Intake Opens: 36.00 Exhaust Closes: 36.00
Intake Closes: 70.00 Exhaust Opens: 70.00
Running Clearance: 0.022 0.022 [Hot]
Valve Lift (Int / Exh): 0.510 0.510
Duration (Int / Exh): 286 286
Checking Figures @ .050" Tappet Rise
Overlap: 28.00
Intake Opens: 14.00 Exhaust Closes: 14.00
Intake Closes: 48.00 Exhaust Opens: 48.00
Duration Intake: 242.0 Duration Exhaust: 242.0
Lobe Lift Intake: 0.340 Lobe Lift Exhaust: 0.340
Intake Center Line: 107
Rocker Arm Ratio: 1.50
cam is a Biggggggg poooooooch ...... no power in a little 273 engine.
Yes Kim ........ that cam won't come alive until 4k and still won't have any power....it will be a "pooch" for sure !
Now...... this d-dart has a serious 273 commando in it . it means business not like the golden commando 65 barracuda . this 66 d-dart is one healthy sb. you can hear the difference in sound of the two cars.
This one has a 340 in it. The original engine was trashed back in 66. Tracey actually raced the car this past weekend with a new engine in it.
Thanks TMM. Hope this works.
This is my D/Dart. The first one built. I believe it currently has the Racer Brown SR-21 cam in it.
ST-21
286 - 254
0.520 - 0.554
Ted Spehar experimented with the ST-12 cam
ST-12
294 - 257
0.480 - 0.512
As released the D/Dart cam was PN - 2843919
Camcraft Cam
284 - 284
0.495 - 0.505
Sorry about the rough idle. Needs new plugs. It is a healthy engine though. Original block, intake, carb ....
