johnthegoalie
- Joined
- Feb 23, 2009
- Messages
- 70
- Reaction score
- 0
1970 dart
25000 miles on engine professionally built by dennis maurer
ran out of gas and stored with mystery oil a few years ago
mp mild cam
mp electronic ingnition
punched .060 over, decked block
milled head with oversized valves
500cfb 4bbl carter carn
offenhauser intake
clifford dual long tube headers
full 3" exhaust professionally built for the car by pro-dyno in tempe az
air conditioniong - dont know if it works, everything there but not hooked up
a-833od 4 speed with a hurst shifter
a guy went through it, has about 4000 miles on it.
needs to be looked at, think i'm running too thick oil
8 1/4 rear end
professionally rebuilt by dennis maurer
around 15000 miles on it
3:55 sure grip
brakes, no brake pressure - i think it needs a new master cylinder and rubber hoses to wheels
there is around 15000 miles on new shoes and drums
suspension
redid ball joints and tie rod ends, has around 15000 miles on them
did not do the pitman, idler and steering box - think they need attention, i was going to do that this time around.
front sway bar installed, rear isnt installed but included
interior
i patched up og headlined, dash pad is cracked but covered by dashmat.
95 neon buckets with simpson lap belts
rear og seat covered by cheapy seat cover
body
faded paint, will need new paint unless you like the 40 year old fade
needs new vinyl roof, found 2 rust spots under vinyl
drivers door pin will need repair, they commonly need this repair on a-bodies
has blue dots in 71 taillights, uncut 70 taillights included
there is a few gallons of gas that needs to be drained, i was going to get it going again, but stopped when brakes didnt hold pressure
car is in az, can ship wherever
pm me for more info
1970 dart
mp mild cam
offenhauser intake
8 1/4 rear end
3:55 sure grip
suspension
interior
body
pm me for more info
