Okay, I got bolts with the right length now, I just have one last question about this thrust plate.
I noticed that both lower bolt holes are "hollow" as to say, won't there be oil coming through that bottom right hole since you cant get a bolt in there?
Took a look at the camshaft aswell and read a bit in the papers that followed, Comp cams apparently recommend that you pull the inner springs before break in of the cam? Is this really necessary? I also wonder if I measured right, that the bolt that goes into the camshaft is 3/8"? With fine threads.
Again, thank you for answering all of my stupid questions
