1969moparDART
Already did wilwood power disk brakes on itBrakes
All the shocks, springs, bars aren't going to mean crap with added HP if you can't stop repeatedly in a controlled manner.
im trying anyway my only problem is funds..... thinking of a GoFundMe account lolWell then, you seem to be set for success.
a comment on sway bars
first run the largest torsion bars you can find
second get the largest front bar you can find
then do a back springs- add a leaf or start with wagon springs then the rear bar
measure a Cordoba bar and see if it fits
they do fit B and C bodies and are cheap at pick a parts
Never do a rear bar first unless you like oversteer like a Porsche
showing a low budget progression here guys
wide wheels (which do not work well with modern tires on OEM 60's suspension) forum can lead you on what fits your chassis
what bolt circle on your hubs?
I love the stanceThe previous owner of my Swinger added a leaf to original saggy springs. It's fairly thick. I wonder if it was out of a Dakota or something. It raised the rear end up and I don't have clearance issues with 255-60/15's but the thing rides like a lumber wagon. I would like to put +1" over Espos and a smaller tire if needed for a better ride.
Model dependent, but why look for old springs to help your old springs when new ones will do the job better than when your old springs were new?did not know wagon springs were different with a bodies
I think your seriously missing something here.disagree on modern tires/ wheels with soft suspension, too much body roll and camber changes
I have found that to be more a waste of time and money.you can get old springs re heat treated and re-arched by any competent spring shop
A Cordoba is a B body with different lean th springs. They will not fit an A body.toolguy measure how far apart your frame rails and springs are-- if close to a cordoba then the cordoba bar is a bolt in get the lower spring plates
if not what A body width cars had a rear sway or do you have to go aftermarket
Buy, start reading...............anything, there are others.Okay I'm putting together a virtual engine for now to get a rough price to build up to, so one of the thing I want is bore and stroke i think I'm only go .020 or .030 over with these pistons
Clevite MAHLE 2242007020: Piston 1968-2001 Small Block Chrysler V8 318ci (5.2L) with 3.93" Bore (+.020") | JEGS
or the identical ones that are .030. As for the stroke I'm not sure yet but I'm wanting a new crank because I don't want to get my original one machined down, so I need some suggesting and preferences for a crank. So that dos pistons and crank, what do we need to make those work together? Exactly I need connecting rods that will work with those pistons and crank which again I need some suggestions and preferences on those and also I would like why you prefer them to others. last but not least I haven't done many cams so I want to know you guys opinions and experiences with every cam you have had any personal experience with, not just hear say but actual experience.
Thanks in advance guys,
Thomas
already got it i just want opinions and input more than anything here, but thanks manBuy, start reading...............anything, there are others.
https://www.amazon.com/dp/1613250584/?tag=joeychgo-20
NICE! Only 12 cubes behind the 340 @ that point. Not a huge deficit.The "308" heads might work with the KB flat-tops at zero deck, but they are NOT closed chamber "quench" heads. I built a .060" over 318 (328") using those very pistons and "302" heads, which ARE closed chamber, but no quench is available with the negative deck of those slugs. I had the heads fitted with 360 valves (1.88 x 1.60") and deshrouded with a mill-job to get the chamber size small again. I used a 270S comp cam ([email protected]", .468" lift, 110LSA, .014-.030" lash range) with 273 rocker gear and a Street Dominator (small port) single plane intake and 625 Street Demon carb. I call it my "baby 340"-LOL-and it pulls my '85 D-150 with authority. Gets 20mpg hwy with 3.55 gears and a 833 O/D trans, sounds lopey but will pull overdrive at amazingly low speeds.
Is that the OE 340 camshaft or upgraded split duration unit @ [email protected] intake duration?
260 MP is shorter on the seat than the stock 340 268
that said the 260 is a lot more "intense" compared to the lazy stock cam
so it should give you more torque and be about the same in the HP dept
let us know how it works
I would not use a stock 340 cam in anything these days- even in an early higher compression 340 you can do better and in a later low compression 340-360 it leaves a lot of torque on the table- get it really revved up it's just ok long closing ramps on both the intake and even more so on the exhaust gives reversion which helps with smog
TMM, you may want to look into the topic of 'roll axis', which is the slope of the line between the rear and front roll centers. With the raised rear, then roll axis has likely gotten too steep. The rear roll center is fixed on that design by the geometry. There is not much to do to fix that without lowering the rear again, or use a panhard rod/track bar, or raise the front. The addition of an anti-sway bar will not much change the rear roll center, IIRC.Someone above mentioned no rear sway bar. My 66 has a front only and I wish it had a rear bar. The front doesn't body roll but the rear does. You get a goofy body twist then. It doesn't need to corner like it's on rails but if the front and rear reacted the same it would be a lot more fun.
Sorry to be disagreeable here, but that is not true. The anti-roll rate is set by the combination of the main springs AND any anti-roll bar. You can have more or less of either contributing to the overall roll spring rate. With no anti-sway bar, then 100% is set by the main springs.Body roll is largely controlled by the anti sway bars.
Minorly by the T bars.
The T bars are for mostly up and down motion. Side to side in a minor way.
