Went out to work on the electric gremlins. It was quite dark in my shop, so I pulled the headlight switch (just because) and the “bright light” indicator light was working! I think it might have been working earlier, but it was too bright in my shop to tell.
On to the horns. I have chased the wires back from the horns to the column connector. The ground problem was in the column/steering wheel area. Borrowed a steering wheel puller and found that there was overspray, body shop dust and old grease that had seized the “wheel on the peg” that grounds to the grounding plate (also coated with old grease and grime) under the steering wheel - sorry I don’t know the correct names of the parts.
Got it all cleaned up, put it back on, shorted the ground wire and the horns worked. Put it all back together and could not get the horns to work when pushing the ring. Figured out the contact plate under the horn ring wasn’t completing the ground. I flushed it with brake cleaner, then WD40. Put it all back together and now the horn gremlins have been defeated.
On to the reverse lights!
