273 Charger/Commando air cleaner!
65dartcharger
Dart Charger 273 Historian
Tavelsjo, Sweden
As all know the 273 Charger/Commando engines all had a chrome air cleaner lid. But some of these air cleaners also got a decal for air filter change.
I'm looking for pictures of those air cleaners with;
- where the decal is placed
- a close picture of it
- where the car was assembled
- year
Thanks in advance
Ulf
You mean a service sticker on the side of the chrome air cleaner?
Mine is a 1965 Formula S, built in the spring of '65 in Los Angeles. The sticker is no longer there, but here is photo where you can see where the sticker was and the vent tube to valve cover not too far from it.
On mine for the Charger label to line up forward, the breather is on the opposite valve cover. Can you measure from breather to left edge of sticker?
The sticker is gone now since the air cleaner was polished so not really possible to measure anything now.
Sorry, my reading skills suck tonight. My bad.
- year
Thanks in advance
Ulf
Ulf....Here's mine...Detroit, MI....1967....original decal, not repro....
Hope it helps!
Here's what I have on a 32k original car. It's probably a C.A.P. sticker. It's unreadable at this point. '66 Barracuda Formula S, L.A. plant, and does have the C.A.P. The hose has the multi-ribs, but, is not molded like what's been shown on a '67 engine in another post.
The red border on the repop is uniform, but the original is thin on side and bottom. The AIR CLEANER is NOT aligned to the PART xx under it. Small font is overall thinner on OEM. Typical, repop is more uniform than orignal....
When I took this picture in 1969, the do-not-wash-or-oil decal was already gone. However, you can see the outline of where it had been - on the driver's side maybe a little more than halfway between dead forward and dead to the left.
My guess is these decals were applied pretty sloppily, and there is no one precisely correct spot for that decal, on 273s or any other motors of that era.
I'm going to go out on a limb & say the quality of the early stickers & adhesive probably didn't hold up real well due to under hood engine temperatures. And not to mention running a car wash wand over them to clean the engine up for those late night weekend cruises.
Thanks!
Thanks! If you turn the lid so you get the Commando name in line with the firewall, where will the decal be then?
