Nice little motor! What is the max RPM on that motor.
On this 273 with the pistons that were used no more than 7000 rpm...
The crank on this one I just used a grinder because I never really touched the two most important counter weights. Those need to go in the mill for shaping way too much material to remove. Plus you touch those and you need $500-$600 worth of Mallory.
