pishta
I know I'm right....
look like hydro rockers....may not pertain to discussion....
I believe the 273 had spot welded tips, probably not enough material to cut and press. These are the harvested slant tips. I took them to a grinder and ground down until the color started changing and did that all the way around and they pulled right out with almost no support left.Cam a guy do that to the 273 pushrods? Pull them apart and shorten them.
A haiku:Are the any oiling mods necessary when using 273 adjustable rockers with hydraulic lifters?
A friend suggested by pre-loading the lifters the oiling hole is compromised?
I would only bother to use factory iron rockers, in there stock form, on very mild applications.
For builds where they might be one of the few affordable options(think T/A heads), where the spring loads were going to be noticeably higher than OE........ doing something like getting them bushed to avoid the galling problem might be something to consider....... if you already have the rockers.
I have dragged the same 273 kit from one stock-cammed 318 engine to the next probably three or four times over the years, since about 1975. BUTAll good info guys..tx.My engine is built and i made no modifications to the new stock shafts or rocker arms.A friend told me that i will be sorry and the modifications are necessary so thought i would ask on the forum.
As you know... i try to use logic and question most everything.
Now....who have used stock 273 adjustable rockers with standard shafts and how did they perform for you?
your right, My cut off wheel made quick work of the banana groove but the holes are proving tough to drill. Ill have to spot and hit 'em with the drill press with a good bit. Only drilling the adjuster oiler for now, will see how the bit holds up. If it cuts, Ill cut the stem oilers in the shaft and arm.Just remember the shafts are hardened & it may take a bit to drill the holes without breaking bits.
just grind a flat through the hardening
I use a dremmel
same thing for trans shafts
like xtra oilers for the od thrust washers
