rigger3006
Well i guess i better just sell it then and buy a "real" cam!
Better grinds is really not so. I went to a car show last year and I saw a really nice 68 gtx 383. It sported the more "modern" comp extreme grind. It sounded like pure crap!! It had lump but a crappy type of lump sound. I I am sure a purple cam can outdo it any day. But that is just my humble opinion folks!!
If you are that worried about what you Hurd about this cam to make you want to sell it and buy a “real cam” you should reavaluate your projo, there will always be a better bader loping cam smoother idle . The 508 cam is perfectly fine. I bump up the idle on mine and I never had a problem out of the whole. It has a good power band. If you want the real thump try wooplash or lunati cams. Ever comp has a awesome selection. I’m a mp /direct connection guy don’t worry about what every one thinks put the cam in fire it up and test it for your self see if you like it.Well i guess i better just sell it then and buy a "real" cam!
I love the 484. 474 Is in my buddy dart. The 508 gets a lot of rip because people just don’t understand is a high preformace cam shaft you’ll like it for sure the 508 has a lott in common with 484Im a purple liker also.wifes 340 duster has 474/280 and my demon has 284/484
The best cam?not too concerned about 1/4 mile performance , never done it. just want a kickass idle for car shows and cruising, gas mileage,same. i seem to remember posing same question about the 284/484 cam,same response from alot of the same members.id sure like to know the end all and be all cam.apparently its out there, popular consensus seems be the 268xe.no thanks
Honestly if you run this cam you have to have the term high performance in the back of your mind. Look at the rpm range for the cam 2800 -6200 street strip. I ran this in a 4 spd worked pretty good I too seen people run the cam at the strip a lot of combos all in the high 11 to low 12 range. I’ve ran the 3500 stall before my buddy ran a 2500 stall with this cam and he dident run bad I think he pulled mid 12s with 10 to 1 Comp. x heads rpm intake. But he drove that for 30k miles all over the states and never complained and he only has 355 gears. And it wasn’t a dog that car really ran good and was a high preformance street car.OMG AJ, can you take up anymore room?
Nut shell it some. Dang!
FWIW, from the Purple line of cams mentioned, the best street manored would be the 280/.474. Stepping up for a pretty good street stripper would be the 284/.484. Best use for the 292 in the street would require (for best street results!) a 10-1 ratio. A pretty high 3500 stall converter and steep gears like at least a 4.10 set.
It is a large hyd cam @ 248@050.
If you move it to the strip, it isn’t so bad. It is a good bracket cam. I have met more than just a few guys running low 12’s with that cam.
Making use of that in the street is mostly a wrong move for most people since making it work requires more than just some work.
Is it me or does half the world think every thing is an install and go part?
Bingo! Ran mine with a 4spd & 4.10’s.Honestly if you run this cam you have to have the term high performance in the back of your mind. Look at the rpm range for the cam 2800 -6200 street strip. I ran this in a 4 spd worked pretty good I too seen people run the cam at the strip a lot of combos all in the high 11 to low 12 range. I’ve ran the 3500 stall before my buddy ran a 2500 stall with this cam and he dident run bad I think he pulled mid 12s with 10 to 1 Comp. x heads rpm intake. But he drove that for 30k miles all over the states and never complained and he only has 355 gears. And it wasn’t a dog that car really ran good and was a high preformance street car.
AJ! Holy cow! I think you got it!This site does not charge by the line.
If you punch "F11" one time and "Ctrl -", several times. you can make it small enough that you can almost not see my posts, which, for you, I highly recommend. Failing that, you can just put me on ignore, then you don't have to see my posts at all.
A freakin MEN!!!!The 484 is streetable if you work with it.
You aren't making Filet Mignon out of a lump of ground chuck!
The 280/474 is a good cam for a streeter as well.
Funkin A to that.War and Peace ain't got **** on some posters on the board!
Works rellly good with 4 spd. I have 391 but with a cam that goes to 6200 bigger in this case Lower gear is always betterBingo! Ran mine with a 4spd & 4.10’s.
A nutshell post!
And no long drawn out math!
Je-zuz H!
Binnnngoooooooo!!!! Lmao not suprised do you remember the post?There is an old thread/post somewhere here. That a member changed out the "ancient outdated mopar cam" for the ever so modern comp extreme series cam and didnt pick up anything but rather lost so many tenths in the 1/4!!! Wow! Go figure the extreme should have done soooo much better since it was a modern latest and greatest cam.
Here’s one for you hot rod mag did a dyno with a 340. It had and air gap 800 eddy and comp 477 -480 lift cam stock bottom end made 390 hp I built a exact 340. But ran a750 eddy and 484mp cam and made 402hp lol and my cam was used in previous builds. Not new might be a 508 I don’t rememberActually more than one member had this dissapointment happen. Just don't really remember when or who but it's in the forum somewhere. I guess it can be looked up on search engine here. But I found it by reading older posts to get ideas and pointers for my build. I'll stick with mopar cams. But also think racer brown and some lunati grinds are nice. However, most all lunati is ground on the typical 110 lobe so that kind of draws my interest more to mopar, racer brown, isky and even custom grinds like say bullet.
A freakin MEN!!!!
Funkin A to that.
More dribble than a baby during teething!
Completely pointless!
