rigger3006
just picked up a NOS 292/508 cam and lifters kit, still in direct connection box with dc break in lube.appears to be from 1980, would anyone recollect who was grinding cams for mopar back then?thanks
Great advice... Hopefully the O.P. understanding and /or asks more questions...Make sure u have at least 165 cranking compression or ur motor will be dead off the line or u could advance it 6-8 degrees to help it out. Kim
Listen to C.B.... He knows his sh"t ... Had a few conversations with him.....If you don't have a true 10.5:1, advance it more as long as you have clearance....
I install those in stock 340's at 100-101 range.
I think you'll be disappointed. I've swapped those for people, going from a 284 to the 292. The 284 outperformed or was equal to a 292 except for about the last 500 of RPM range.
im yanking out the 284/484 and using this one, p4120233, 76 deg overlap,108 cl.3000 stall and 391s with 295s out back, may advance 4 deg, not too worried about a dog out of the hole
Look at it this way, would you want it to be a dog out of the hole?im yanking out the 284/484 and using this one, p4120233, 76 deg overlap,108 cl.3000 stall and 391s with 295s out back, may advance 4 deg, not too worried about a dog out of the hole
thanks for all the advice guys, all i really wanted to know was if anybody could recall who was grinding cams for mopar in 1980
He said it was in a DC box, ....AFAIK that predates the wide lobe separation version,.........and listed the "233" P part#w/76 deg OL, so ...................unless there was aMake sure which version you have. There were two. One ground on a 108 and one on a 112.
Expect ~9-9.5"Hg of vacuum, and You'd better plan on a 9.5" torque converter if You don't have the above squeeze or advanced as recommended, unless You're runningim yanking out the 284/484 and using this one, p4120233, 76 deg overlap,108 cl.3000 stall and 391s with 295s out back, may advance 4 deg, not too worried about a dog out of the hole
switcheroo............
@Bighead440 Maybe he can shed some light on which company was grinding the MP cams int he 80s.
