3/4" M/C? I would be very careful with that & disk brakes. A prayer to Allah would be a good start. The m/c volume is the problem; you have a LOT less with 3/4" compared to a a 1" m/c. 44% less volume to be exact....
The m/c body would need to be quite long to hold enough volume without the m/c piston bottoming out, plus a safety margin. You will also have more pedal travel, pedal may hit the floor. Some serious calculations would need to be made...
Sounds like , 'It was a good idea at the time...'
