Phily
3XL, loud pipes, loud music, loud weed
Not an a body sorry. Most active site I'm in tho.
So my 05 grand caravan 3.8 shows a misfire and I can feel and here it. Kinda like a Tupperware popping.
Now I thumb checked compression and it seems to be getting plenty. I have read somewhere that it could be in the wire harness of the fuel injection. I don't have a micro camera to stuff in there to see if all the valves were opening but I'm sure since there is enough compression to blow my thumb off no prob that they are closing or at least stuck closed. I didn't notice it sucking on my thumb either.
New coil pack was installed a few months ago and that definitely seemed to help with overall engine performance. Sounded a hair bit more, how do you put it, perky and clean? No real noticable power to say.like maybe it was getting a more powerful spark and ignition g the cylinders better
The spark plug didn't look bad. Maybe a bit hotter than. I'd like. But a slight tannish color and not blackened or melted or anything. So I think it's sparking but maybe not getting getting gas.
No codes saying injectors or fuel. In fact codes if I remember right are misfire cylinder 1, seat belt sensor malfunctioning, there might have been one more.
So sometimes a problem can be due to something completly diff but can still effect other parts of the vehicle. Like a bad grounded abs screwing up shifting in an alero. It happens and have seen it other times as well . So here is a list of things that should have no bearing on the issue( and is probably pointless to read) would be my driver seat doesn't move up and down where my *** sits but reclines back and the front part by the knees move and the pass side window visor that has a light got ripped out. O and my driver side back door doesn't open or close itself, but clicks like it something is recognizing it.
