3 Spoke Steering Wheel Resto - My Way
pntastar69
Gilbertsville, PA
Picked up this wheel from a FABO member a while ago. Let me add that it wasn't a basket case but it was a 40 year old wheel. I chatted w/a few guys that restores wheels and got some pointers from them on “how to” redo. The spokes were severely pitted, the rim had the usual ½” cracks/separations, and the rim was slightly bent. I called a few people and inquired about $$$ to restore them and I said, I’ll give it a whirl. So, this was my winter project and I just installed it last week. I removed all of the material on the rim and exposed .380” round stock that was welded to the spokes. I also had to straighten out the bent portion of the wheel. I inquired about replating the spokes and opted to blast the spokes and have them powder coated. Once that was done, it was time to start building up the rim with f-glass and epoxy resin until I achieved the correct diameters so the stainless inner and outer rings fit snugly. Many, many applications of cloth and resin were applied and lots of manual sanding w/60 grit to form the rim portion. Once the rings fit snug, more epoxy resin was applied to lock in the rings. I used epoxy products from West Systems. Picked them up at a local marine dealer. They also had colloidal filler to thicken up the mixture to prevent runny epoxy. After sanding it to the OD and ID, it was time to cut in the grooves for the grips. My friend had a NOS wheel and I used it as a template, and marked the wheel to indicate the high spots on the grips, all 48 of them. I made a jig to lock the wheel in place and used a dremel w/a ½” 60 grit sanding drum. I set it up so the depth was the same for each groove and tried my best to center the sanding drum between the high spot marks. Once I cut the 48 grooves, I used a curved bastard file to form the grips. A final sanding to my liking and some filler, I started masking things off. I wanted a black wheel w/out the grain effect, as my interior is black and has no woodgrain. I masked off the spokes, masked off the ss rings and had the wheel etch primed. A quick sand and the wheel was painted black. The mask was removed from the ss rings and the entire rim was then clear coated satin. The masking was removed from the spokes and whala. I had a paint/body shop do all of the painting, etch primer, basecoat, clearcoat. I wasn’t looking for concourse, but a nice appearing, different, to my liking, wheel. Would I do another one, maybe.
Looks great but I wouldn't have the patience to do it myself. Looks like a lot of time consuming work.....like body work.....bores me to tears. I'd rather hire someone else to do it!
I'll admit that reading your method, I was skeptical...but the proof is right there- awesome job:thumblef:
...and that's the kind of thing I'd do, too:smile:
I love the jig for the grooves. True artist. You have much more patience with fiberglass than I! Cheers.
Matt
Holy Molly!!! Very well thought out and superb job!!
Pretty sure I sold you that original wheel...OUTSTANDING craftsmanship there! Have another one just like it kicking around here if someone wants to get ambitious.
Hell yeah. Outstanding! Not to mention you saved hundreds if dollars. DIY at its finest.
Pride in workmanship anad ownership. That is one nicely restored wheel. Love seeing guys using the old noodle. I guy a worked for used to say this all the time, (YOU JUST HAVE TO KNOW HOW TO HELP YOURSELF).
Almost 3 years later, my post reappears. Thanks guys. You can't imagine how long it took and how many discussions I had w/the 2 guys who do this for a living. Doug Lepak and Dave Tays, great guys to deal with. I am doing another wheel that is currently playin hostage at the powder coater. No, not gonna get in the business restoring these wheels if you guys are considering inquiring.
