furydan
not so junior member
So I got a set of 302 heads from an 88 fifth avenue for my 71 318 block. I noticed there are holes on the exhaust port side of the heads below each of the exhaust ports. I guess they are some sort of pollution control fixture. When I pulled the heads from the 5th ave, it had those metal tubes attached to the exhaust manifolds. What am I supposed to do with these holes when I go to put the factory early a body exhaust manifolds on? The holes are not going to be covered by the manifolds. I just spent 400 on these heads so I hope I will be able to use them.
