318 Freeze Plug
Bts68cuda1
williamstown
So I finally get to work on my 1968 Fastback Barracuda 318 and I was told that one of the freeze plugs in the front of the motor leaked. So I looked visibly and couldn't see any issues so I filled up the radiator and it started pouring out the bottom of the engine. I looked and put my hand down behind the passenger side motor mount and felt a rusty hole. I'm assuming that I now have to lift the motor to replace a freeze plug put in an absolute horrible spot. Any guidance , tips or insight would be appreciated.
NAPA actually sells a rubber screw in soft plug.
It is a metal plate on the outside with rubber in the middle, you tighten the bolt down, it was designed for tight spots like that.
There are two of them that has been my dads truck for over 10 years.
If 1 of your freeze plugs is leaking, chances are the other plugs are in similar condition & will need to be replaced too. I'd change them all if you can...
They are called expansion plugs. They work great. If your not ready to pull the motor, Id drop the $3.99 for an expansion plug any day to extend the inevitable for a down time weekend.
it has always been my experience that the first plugs to go on a small block Mope are the drivers side, then the rear soft plugs, then the right side. I think it has to do with the way the water circulates. It seems to push all the sediment(rust, sand, etc) CW through the engine and it settles mostly behind the soft plugs, left side first, where it accelerates the rotting process. They aren't all hard to replace, except for sure the rear ones, so I'd test all the lower block soft plugs with an awl or a sharp flat-blade screwdriver. If you find any weak ones, I'd replace all the lower ones. If that happens to be the case, I'd pop them all out at the same time, and use a bent coat hanger and garden hose and fine nozzle to irrigate the water jackets thoroughly through the soft plug holes, so you flush out all that nasty sediment. You'll probably be surprised how much is in there. Your cooling system would thank you if it could. If you want to go the extra mile, you can replace with brass plugs, there just a little more expensive, but they are much more corrosion resistant.
should have seen the crap I washed out of my 68 273. about a lb of "dirt". Remove rear plugs and front ones and direct water jet into fronts. when it runs clear, then take off sides and repeat.
I also gently scrape with a long screwdriver to help get the crud out...
The rears were a solid wall of crud behind the plugs, like plaque.
You have to be careful scraping that out with a screwdriver so you don't put too much pressure on the block and crack it... Gentle but firm...
I started to laugh, but I have to stop choking first. Since you didn't include the "lol", I'm pretty sure you speak with authority, so, can you elaborate a little?
Yeah, get the big craftsman flat blade screwdriver and pry sideways between the bores in the water jacket and you can get enough torque/twist crack the block/bores...
You have to scrape hard enough to get the scale off, but not too hard to stress the metal... There are some nooks and crannies that the screwdriver blade can wedge into and you may be able to do damage...
So firm but gentle when scraping out the block water jackets...
