318 stroker
dementeddart
Member
cloverdale indiana
I made a video of my 318 stroker idling it has 11.5 to 1 compression 525 lift comp cam with roller rockers eddy heads. 4.10 ratio 8.75 rear end. runs 12.20 in the 1/4 with street tires and exhaust.
[ame="http://www.youtube.com/watch?v=vtwmJcBlDV8"]YouTube- 1971 dodge dart 318 stroker[/ame]
Post the details of the engine build. I have a 318/402 Stroker on my engine stand going into my 67 Dart.
MORE Info!!!!!!
Here is a thread I started about the 67 dart I am currently working on.
http://www.forabodiesonly.com/mopar/showthread.php?t=101437
Here is what the engine has in it. I will have $4100.00 into this complete engine Carb to Pan
All machine work was done by Brian at IMM Engines member ou812
318 Block offset bored by Brian at IMM Engines member ou812
4.0 Cast Scat Crank
Icon Forged Pistons -20.5 Dish
Eagle SIR 5140 Rods with ARP hardware
62cc RHS Heads by Brian at IMM Engines member ou812
Stock NEW oil Pan with windage Tray
Stock NEW oil Pump and pick up
Hughes HYD Flat Tappet Cam
Camshaft Technical Details
Intake Valve Lift 1.5
Exhaust Valve Lift 1.5 .569"
.576"
Intake Valve Lift 1.6
Exhaust Valve Lift 1.6 .606"
.614"
Intake Duration at .050"
Exhaust Duration at .050" 246°
250°
Lobe Separation Angle 108
Intake Opening at .050"
Exhaust Opening at .050" 18° BTC
56° BBC
Intake Closing at .050"
Exhaust Closing at .050" 48° ABC
14° ATC
Min. Suggested Cylinder PSI 185
Sweet Spot RPM 2800 - 6100
Johnson Lifters
Hughes 1.6 Roller Rockers banana shafts and hold down kit
Manton 3/8 hardened Pushrods with 5/16 tips oil thru
Cat Gear Drive
Eddy RPM PERFORMER Dual Plane Intake
Holly 1000 HP Carb/ or equivalent not purchased yet
Recurved Stock Distributor
Digital 6 Ignition
A904 Transmission with Transbrake and manual reverse valve body
3500 Stall custom built by TCS- The Converter Shop
Shortened 8 3/4 with triangulated 4 link by ME and a NODULAR 489 Case w/3.91 Gears & 3 way adjustable coil overs.
Mini Tub by ME
15x10 5.5 Backspace with 325/50/15 MT Street Radials
She is a 1971 318 block bored .60 over
kb forged pistons part #kb846.060, (11.5 to 1 appox with head)
4" stroke forged eagle crank
stock rods
525 lift 305 duration comp cam hyd flat tap Part #20-244-4
comp cams roller rockers
edelbrock alluminun heads (straight out of the box)
edelbrock single plane torker 2 intake.
750 duoble pumper holley carb
unlite mallory ignition with highfire box (all ignition mallory)
crap headers
3600 b&m stall converter
727 trans with b&m complete kit
8.75 rear end with 742 suregrip carrier 4.10 ratio
stock rods
crap headers
Did you use Custom Pistons? Your bore would be 3.970 correct?
Mine was offset bored to 4.0 so an off the shelf stroker piston would work.
WOW! What a bad a@@ maternal fornicator! LOL :toothy10:
whats it run with slicks and opened up?
Don't know I spin a little off the line but not much. I don't have any slicks to try.
Off the self pistons they are in KB catalog page 21. Bore size is 3.97 I think it makes my total cubes to 396
wow!I love the sound of that cam and the way it idles!:cheers:
What kind of mods to the heads and valves are needed for a cam like that?
Ok, so the ones based on the 390 kit............Cool! Those are forged right?
Sounds great! I am wondering how these 318 strokers compare to the 360 stroker kits that are out there? Running on pump gas of course. Have you had the engine dyno'd?
I am going to have mine dyno'd at Brian's Shop before I install it. It is only a 10.20:1 Pump Gas Motor. I had my 410 that is in my 70 Dart Dyno'd at Brians, I am glad I did. I had major oil leaks from the valve covers. It would have been a MESS with it installed in the car to get cleaned up. After 5 min on the dyno BOTH gaskets just started Pouring out oil all over the place.
Nice thread, I want to do a 318 stroker also. So all the info from you and others on this is greatly appreciated! I had a '71 318 that I back yard rebuilt that had the heads milled down .030. I put a holley 650 on it with an eddy manifold. Thats all. I was such a noob I could not for the life of me understand why the 4 barrel never opened! LOL. I had a chance then to do a lot more with that car.........Anyway, like the thread. Thanks all!
Ummmm, that's not a Torker II on the engine in the vid. Change it out???? Looks like a Victor.
12.20 in the 1/4 with what ya got isn't bad! More stall and some slicks...Muha ha ha ha ha
Whatcha got for rear suspension?
Sounds a lot like the motor I'm building right now, cept mines a 67 date code block, same exact pistons, rhs heads, solid cam, scat rotating assembly, m1 intake with 950cfm carb, and fender well headers with 1 3/4 primaries and 3in collectors.
Having the same cubes as a Chevy bb from a 318 is a laughable subject..:toothy10:
Almost forgot, she runs on e85.
And if they want proof, it says so on the side of the block.. haha
Yes my mistake it is a victor 340. #-odon't know what i thinking lol. Sorry for the slow reply just got back from vaca.
