srt8
1971 340 bored .30 over complete from carb to pan what you see in picture is what you get. From the top BG 750 carb with pro-form main body, holley air gap strip denominator intake,w2 race heads with copper head gaskets , black mopar valve covers, huges racing custom blower grind solid cam I have cam card for buyer, je forged pistons 7.5:1 compression, eagle 6.123 H beam forged rods, stock steel 3.31 crank, mopar high volume oil pump, morso 7qrt oil pan, accel distributor, wires with ngk plugs and mopar water pump. Atchinson Machine and Racing o-ringing the block , heads, installed all bearings machined and line hone the block. Remp Racing in leamington assembled the entire motor. Estimated n/a horespower around 425. $3250 obo
