eeka440
I have a 73 340 intake with a ThermoQuad on my 1968 318. Stock heads. Runs awesome!
The two instances I remember, both had a 340 intake on an otherwise stock 318. In both cases, the ONLY thing we changed was the intake manifold, and the bad hesitation they both had disappeared. IIRC, (this was over 35 years ago, so, some details might be mixed between the two), the 1st setup was a '69 Dart with a '68-70 340 intake and a Holley 600 vacuum secondary. The head castings were the stock 675 castings. The rest of the engine was also stock, including the exhaust manifolds, single pipe system, and camshaft. We reused the carb and air cleaner without changing anything. Same distributor and timing specs too. The second time was basically a repeat of the first, except it was a '68 Barracuda that had a aftermarket dual plane aluminum 340 intake...I think it was a Wiand. Same size Holley, and the rest was also stock '68 single exhaust along with the rest of the engine. Both had aftermarket open element air cleaners with new filters (one of the first things we tried in order to get rid of the bog, including full tuneups). I never ran across that exact situation again, but, I got out of the retail repair business soon afterward, so, I expect I would have run across a few more if I continued in that type of work. No way to know for sure though.
May be it helps break the fuel charge up more. Who's to say!It will work fine the port mismatch doesn't matter. When I was younger people always told me it wouldn't work and never ever do it because the fuel will smash into the edge and bla bla bla its all myth. Think of it like the the carb doesn't push the fuel down the intake. The pistons suck it like a vacuum. So even with the lip there the engine is gonna suck it right over the edge. Iv had the same 340 intake on 4 engines 3 of them were 318s 2 of those were 302 heads. On the first one I took a dremal and gasket matched the heads to the 360 gasket the the other 2 I did not and I couldn't tell any difference.
Maybe thats a good theoryMay be it helps break the fuel charge up more. Who's to say!![]()
That sounds like 'what if that JB broke off and got sucked into the engine...?"I ran a W2 strip Dominator on 340 heads...worked. Terrible port mismatch (round pin in a square hole) still worked great. I even JB'd a little ramp into the W2 ports to make em more square and they were still there 6 months later when I took them off after I found an LA SD intake. I wouldn't attempt that again; a little older, alot wiser.
Ran one on a 273 for years, ran great. Stock heads, except springs, AFB, .060" over 11.5 to 1 Jahns, SIG Erson cam and springs, dual points, Cyclone fender wells. 4.10 SG. and 4 speed.Any reason not to put an original 1970 340 intake on a mid 70s 318? I found one local for not a bad price. Just want to make sure it will work well. My plan is for a mild street 318 (~300hp). I’ve got some 302 heads for it already.
no it will fitAny reason not to put an original 1970 340 intake on a mid 70s 318? I found one local for not a bad price. Just want to make sure it will work well. My plan is for a mild street 318 (~300hp). I’ve got some 302 heads for it already.
probably emissions EGR...maybe?Makes me wonder why Chrysler decided to foot the bill to make 318 4 bbl intakes when they already had the 360 4 bbl intakes on the shelf. Same thing with the 2bbl's. There had to be something different that warranted casting a new manifold. Later on of course, they used the same manifold, but, the ports between the two heads were a lot closer in size.
Have you ever SEEN one IN PERSON that had 318 size ports? I've not. That doesn't mean anything, but I've never in my life seen one and I've pull a good many off in junkyards. Always had the 340/360 port size. I've seen some the casting number decoded to "318" but they still had the large port size.Makes me wonder why Chrysler decided to foot the bill to make 318 4 bbl intakes when they already had the 360 4 bbl intakes on the shelf. Same thing with the 2bbl's. There had to be something different that warranted casting a new manifold. Later on of course, they used the same manifold, but, the ports between the two heads were a lot closer in size.
Go tell what's left of Chrysler they're asleep too because they did it with millions of 318s right from the factory.You all must be driving in your sleep! To put a set of 360 340 heads on a 318 without matching the ports is a waste of a lot of time and performance. To start with the ports are large enough the 318 is going to suffer in response and power. If you match the ports in the heads than it would work acceptable but not optimal. I tried it and wound up installing a 273 single plane and the engine came to life. The engine had ported heads with headers and early 340 cam. It ran fair with the 340 intake but I had already done a match up of the ports. Now if you use the 360 heads with the 1.88 intakes and the manifold stuff lines up a lot better and upper rpm perf is a lot better but the low end suffers some. It's the same with any engine accept a BBC which is always under valved no matter what combination is being used until you get up around 2.030. READ up on cylinder heads and port design. Some here are saying just run it but if it's worth doing, do it right and match the heads up to it. You will be glad you did. I ran mine with a TQ at first also and it worked ok but it worked be with the AVS and the small port 273 intake, it was way better off the bottom and the top didn't seem to suffer much, it was noticeable but I dealt with it because I like anyone else isn't in the throttle to the floor all the time, just part of the time and an engine that stumbles off the line is nothing to brag about no matter how hard it runs above 3k, you've already lost the race and playing catch up isn't a winners game.
The 73 340 intakes all had the EGR jets in the bottom of the plenum. There might be some late dated 73 intakes out there with external EGR provision, but they were for the 74 model year.Most '73's and all '74-up intakes had provision for an EGR valve.
I have seen only 2. Came factory on a 78/79 1/2 ton. I did measure the ports which were the small ports. That was in the late 80s or early 90s. Haven’t seen any since. KimHave you ever SEEN one IN PERSON that had 318 size ports? I've not. That doesn't mean anything, but I've never in my life seen one and I've pull a good many off in junkyards. Always had the 340/360 port size. I've seen some the casting number decoded to "318" but they still had the large port size.
