360/72' Duster - Please help me
osxdos
72' Duster / 360
Dayton, Ohio
Okay, i bought car as is, so far, i cant get the turn signals to work and the back right tail/break seems a little dim, ive bought so many bulbs its ridiculous, its all original wiring, the battery and fuel cell is in the trunk, i upgraded the battery to a bigger one, with 750 cold cranking amps, now. after tons of reading, oh yea i for got i was gonna test the turn signal switch, which im gessing is behind the steering wheel, but when i turn the headlights on okay all the lights car idling, hit the turn signal nothing both sides, then i hit the break then try, it reduces one break light to a tail light, and i try the other way and same thing just different side, so i think the switch works, i found the turn signal relays two of them and i think its weird but their only 2 prong. :/ i have a analog multimeter to test but barley know how to use it. ummm only other thing is license plate light has a bulb in it but it dosent come on either but i took it out and it looks good, i put brand new 1157s as a pair in rear and the front has amber colored new bulbs i dont think their 2057s though. but should work, new as pair.the guy that had it before me added RPM tac, and HEAT, OIL, and ummm something else
Could be the bulb sockets themselves too. Sometimes when they are rusty they will cause this type of thing. Grounds and bulb sockets, first things to check/replace.
x2.this is where you need to start
