360 build, hp and compression thoughts!
107's with 72 cc, 4.125-.040 gasket, .010 in the hole will be ~9.5 static. With a .050 gasket it's ~9.35.
I'd leave the black bushing on the distributor. I pretty much use nothing but the black bushing anymore.
A 1" open spacer would really wake up the performer intake. Would require jetting up the carb a bit.
The car would like more converter without a doubt, a true 2500 would be good, if you want it to really make a move in the 1/4 or 1/8, 3000-3500.
It all a learning experience. Some are a gruff, some tactful.
Hmmm... i had questioned the convertor as well and wished i had more stall.
Hi,That calc is good but you may want to go and check this App. It allows for static and dynamic compression ratio calculation, displacement, head power potential and more, it even has your Mopar engine data inside! It's available for iOS and Android devices! There are other Apps for chassis and EFI in the site, give 'em a quick peek!Website:http://www.hotrodderapps.comiTunes:https://itunes.apple.com/us/app/engine-2lbox/id576224443?ls=1&mt=8Google Play:https://play.google.com/store/apps/details?id=com.mexicanchevyshotmail.com.mexicanchevys.engine2lbx
Hi,That calc is good but you may want to go and check this App. It allows for static and dynamic compression ratio calculation, displacement, head power potential and more, it even has your Mopar engine data inside! It's available for iOS and Android devices! There are other Apps for chassis and EFI in the site, give 'em a quick peek!Website:http://www.hotrodderapps.comiTunes:.../app/engine-2lbox/id576224443?ls=1&mt=8Google Play:https://play.google.com/store/apps/details?id=com.mexicanchevyshotmail.com.mexicanchevys.engine2lbx
Nice Link, I'll have to Check that one out when I get home.
9.5 to 10.2 at .oo5 decking where they sat, they should be without decking a gr8 cam
up ypur stall and put a 750 carb on and your ready to rock the 3:91 will be fun 3000 stall is what the cam calls for get an intake that will pull 2500 thru6500 and your good , make sure you got good brakes 400 solid hpgive or take 15 with 2.02 heads workem or get rhs/indy you can pull 450+ out of it its your tourqe thats gonna count for street and little stripp or bracket racing
