360 Engine weight help
I had mine weighed at a UPS terminal. It weighed 439lbs. It has aluminum heads, and was minus water/fuel pump, pulleys, brackets, carburator, and alternator (long block).
Hope that helps.
I think I remember reading a while back,....a cast iron headed small block weighs around 650-700 lbs full dressed.....and big blocks weigh over 900 lbs fully dressed.
Hope that helps.
i'm sure I read 575, thats probably bare (without ancillaries) and would tie in with Prine's figure above.
I remember checking before I used an engine crane.
