yellow rose
Overnight Sensation
So now decision time. Matt will probably use the PRW rockers. His springs are good for .600 lift, but I don't think I want to push stock rockers that far. I already have a set of the comp studs, and junk comp magnum conversion guide plates that don't fit. We will have to cut a strip out of the guide plates to get them to align the rockers on the valves, because the pushrod slot spacing is wrong.
Just remember, if you are checking P/V and rocker ratio with checker springs rather than the springs you'll be running, you'll see much more rocker ratio. All rockers flex and all rockers if they are worth a crap will have extra ratio built into them. You'll also gain even more P/V with the springs your running over the checking springs.
